Question about Craftsman Garden
2500 pressure washer 2.3, its running noe buy the water will not come out of the nozzle..whats wrong?
    Sergeant:
  • 259 Answers
Check he screen where the hose screws in. There is a screen inside the fitting you should clean. Take it out carefully by using a screw driver around the edges and make sure the screen is clean. After you put the screen back in take the hose off the gun and see if water comes out of the hose. If it does you have to take the gun apart and clean it.
Posted on Mar 20, 2011
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
No pressure out of wand have water flow old style wand no turbo motor runs good sounds like it should be full pressure
Hi and welcome to FixYa, I am Kelly.
From your description of the problem:
"motor runs good sounds like it should be full pressure" This sounds like the wand nozzle is clogged behind the nozzle. Remove the nozzle and check for debris behind the nozzle face. All it takes is for a tiny piece of particulate to block the nozzle orifice. (Dig out what ever you find behind the orifice. After you check and re-test the nozzle if you still have the problem there is a lot more that can be done to troubleshoot. I just think you have a clogged nozzle at this time. If the nozzle was not clogged... respond here and I will pass on more information. I think we can easily correct this problem.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Karcher 2500 PSI Pressure Washer
Why want my pressure washer suction the solution while pressure washing the house?
The first problem might be that you are trying to use the wrong nozzle, see this link to read more about what nozzle to use for detergents
If you still have an issue the problem is going to be in the chemical valve on the pump, there are two different styles they have on this type of machine, look at the links below on directions on how to repair your chemical valve.
Chemical Injector 1
Chemical Injector 2
Nov 11, 2010 | Karcher 2500 PSI Pressure Washer
When pressure washer engine is running and hooked to water supply, there is no water spray with trigger is depressed
Hi Have you checked that your nozzle in the lance end is not blocked. Please try this and then try without the high pressure hose attached.
Oct 27, 2009 | Karcher 2500 PSI Pressure Washer
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Oct 28, 2008 | Karcher 2500 PSI Pressure Washer
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
261 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
