Kenwood DNX573S
1 Search the unit ("DNX****") from your smartphone/cell-phone.
2 · Confirm the request both on the smartphone/cell-phone and the unit.
· Input the PIN code in your smartphone/cellphone.
PIN code is set to "0000" as the default.
3 Select the hands-free number to connect.
A name of a smartphone is displayed when it has handsfree connection with the unit.
By this way you can connect your bluetooth.
Get a Google Drive and have everything backed up to it, then it will be available on any device you want. You can set it up so that it only does it when you are on wireless so that you don't eat up your data allotment.
On the cellphone menu there will be a set of preferences and settings for Bluetooth. Scroll through the menu options. Make sure the headset is on. The phone should list the detected devices. Activate it from that menu.
Hi, your problem is need to reprogram your cellphone or try this also maual reformat to your cellphone just dial this *#7780# and default password nokia 12345.but before you that reformat you need to back-up your files to memory card and save your contacts to sim memory.after you that the cellphone is back to normal setting .i wish that i help your problem.thanks
First you need to pair your bluetooth with your cellphone. Go to your cellphones manual and look on how to pair it with a bluetooth. You would need the passcode for pairing, after that then you connect your bluetooth to your phone. Sometimes it depends also on what kind of cellphone you have. Some older model of cellphones are not compatible with the newer bluetooth. Let me know if this works.
Passcode is the temporary code for wireless devices when pairing with each other to establish a secure connection. You can assign any numbers or codes you like for the connection to take place. Suppose when you are asked to enter the passcode, enter 123 on the computer's passcode box and then same 123 on the cellphone. It'll automatically accept, but you need to assign the passcode everytime you connect the devices (as I've mentioned for once connection only).
You can assign any numbers or letters as passcode, but it should be set the same code on both the devices.
Hi
in order to connect a BT to you phone follow this steps:
how to connect a bluetooth to a cellphone 1. go to the menu on you cellphone and find connections-bluetooth 2. click options 3. be ready to click search for device (don't click yet) 4. press the on button on your earpiece and hold till you get a solid bluelight (about 6 secs.) 5. when you get the solid blue light on earpiece click search for devices on the phone 6. when it finds your device select it and click on it 7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000 for code 8. it will ask you to confirm click connect you should be able to connect.
Turn on your cellphone's bluetooth, try searching for a new device. If found, select Jabra BT150 and enter default passcode "0000". Nice bluetooth headset, Goodluck.
You must turn on bluetooth in your cellphone in connection setting first, then turn on also the bluetooth in the other device, if done try to search bluetooth device in your area using cellphone..until it detects the device you want to share files with.
you must enter the same code on each device if required then now you can share files ..
