Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
My heat runs, but does not shut off......my ac is not working..I need help with which wire goes where on the CT87N??? I currently have the blue wire in the W , the red wire in G, the green wire in R, and the white wire in Y. Please help
  • Revefr3 Mar 19, 2011
    Are blue, red, green and white the only colors you have for the thermostat or are there more?
  • 4 Answers
I'm not sure if you received my clarification request or not. I will assume that the only colors you have for wire are what you stated in your problem description. Attach the red wire to R, the green wire to G, the white wire to W and the blue wire to Y..
After you have done this, make sure to look in the air handler to be sure the wires are tied to the same terminals inside as there should be a terminal board for them.
I hope this helps you get cool.
Rev
Posted on Mar 20, 2011
Ct87n thermstat is hooked up and the heater is on because i smell the heat but it is not blowing out the vent
The blower motor isn't running. At the thermostat, red wire to the R terminal white wire to W terminal.or W2 If the blower still doesn't run It's probably not the thermostat.
Nov 07, 2014 | Honeywell CT87N - Round Heat/Cool...
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
The compressor fan come on; I can hear a clicking (the compressor trying to click on, then immediately shut off. It will contiula doing this as long as the thermostat is set for the ac to come on. I...
Possibly a bad run capacitor, have a service tech test it and replace if it is bad. That clicking you hear is the internal overload in your compressor clicking off on high heat/amp draw and then cooling down and resetting itself.
Jun 16, 2011 | Heating & Cooling
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I recently installed the Honeywell ct87n thermostat.....the AC worked fine all summer, but has been off now for 6 weeks. When I turned in on to heat / automatic...nothing happens...neither the AC or Heat...
Check for a fuse in your AC/Heating system either on the control board or in-line on a wire. Make sure the wires are correct to the thermostat.
Oct 05, 2010 | Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
I have a heatpump wired as in diagram fan works a/c works but not heat what do i do?honeywell CT87N
On the sub base jumper R to RC this will allow it to work in heat.Just Run a wire from r over to rc termminal and try it. If it does not work get back to me and I will help, Rus
Dec 05, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Jul 02, 2009 | Ruud UBHC Air Conditioner
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
175 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
