Question about Kodak S100 Webcam
I just installed this and when I click on monitor or record video I get kodakwebcamsexe has stopped working
Setup webcam on facebook
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right tick in either windows software or the all software box. If you don't have or cant find the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html It might take some time being a freeware driver solution Note: This will find all of your outdated drivers This program will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer b> b> Go to Facebook and log into your account. Click the "Profile" tab. Click the "Video" link in the "Status" menu. Select the "Record a Video" option. For privacy reasons, Facebook requests permission to access your webcam and microphone. Check the box next to "Allow" and click "Close." You will appear in real time on the Facebook webcam window. Position yourself in front of the webcam and click the red "Record" button to begin recording your new video. When you're finished, press the "Stop" button. Click the "Play" button to view your video. If you want to post it on your profile, add a brief message and click "Share." If you're not satisfied with the outcome, press "Reset" and record a new video. b> Video Message Log into your Facebook account Navigate through your friends list and select the friend you want to send a video message to on Facebook. Click the "Send Message" link in the upper-right corner of your friend's page. Click the "Video" icon in the attachments section at the bottom of the "New Message" window. Check the box next to "Allow" to give Facebook permission to access your webcam and microphone, and then click "Close." Press "Record" and record your new video message. Click "Stop" when you're finished recording. When you're finished recording, you can press "Play" to preview your video.
Mar 15, 2013 | Microsoft LifeCam HD5000 Webcam
Can i record a video on A4tech PK-635 Web Cam
Yes you can. You can either use the webcam's included software amcap or you can also use Windows Movie Maker.
To do this, follow these steps:
  • Go to your Windows Movie Maker Movie Tasks and then select "Capture from Video Device".
  • Select webcam from the list of analog devices.
  • You must also select the video input line you want to use for capturing your webcam video.
  • Then enter a name for your captured video file and the location of the drive where you want to save it.
  • Select your video setting preferences for the video you want to capture.
  • To stop capturing, you can either choose to stop anywhere during the recording session or indicate a specific time limit before the recording stops.
Hope these steps help. Goodluck!
Mar 29, 2011 | A4tech PK-635 Webcam
How can i install my web cam?
Hi,If you don't have CD for installation, Use the below link to download it.
(microsoft.com/hardware/download/download.aspx?category=ICE)
Set Up and Use the VX-3000 personal web camera
  • 1 Install the software using the included CD and plug the LifeCam into a free USB port. For desktop use, place the LifeCam on a clear spot on your desk that's free of other objects, including cables. The camera should not be more than an arm's length away from you. For LCD (or similar object) use, push the center part of the camera's base upward, place the camera on the LCD and close the base around the monitor to secure it.
  • 2 Open the device software by clicking the Microsoft LifeCam icon on your Windows desktop. If no such icon exists on your Windows desktop, click "Start," click "All Programs" and locate the Microsoft LifeCam program in the list of programs there. After launching the LifeCam program, look at the image that appears. If necessary, adjust the camera to more precisely reflect your appearance. For best results, try to center the camera image on your head and shoulders.
  • 3 Click the video camera icon on the bottom panel of the LifeCam program to begin video capture. Video will begin recording, and you will see a "Recording Video" message beneath the live video image. To stop recording, press the same icon (the icon will have a red square with a blue background during recording).
  • 4 To begin audio capture, click the microphone icon on the bottom panel. To stop the audio recording, click the same icon (again, it will have a red square with a blue background during recording). To snap a photo, click the camera icon on the bottom panel.
  • 5 Access any of your captured video, audio or image files by clicking the folder on the bottom panel. The VX-3000 also provides the ability to edit video or image files using supported software. After snapping a photo or capturing video, click the "Edit" icon that appears beneath the thumbnail of the captured content.
  • Hope it helps.
    Oct 30, 2010 | Microsoft LifeCam VX-3000 Web Camera
    I dont know how to install my new lifecam !
  • Oct 09, 2010 | Microsoft LifeCam VX-3000 Web Camera
    Feed realtime audio and vdeo from webcam back to laptop.
    Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
    Click OK and it should work.
    Hope this helps. Bud
    Sep 17, 2008 | Labtec Webcam Pro
    Instant DVD Recorder stops working when I try to capture
    Please try to uninstall the program Instant DVD Recorder.
    Download the latest version of Instant DVD Recorder in the link below which is the 2.6.
    http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1
    Make sure that the program that you have must be uninstall first before you start downloading the file and install it.
    Jul 18, 2008 | Pinnacle Dazzle DVD Recorder
    How do you playback video record
    If you installed some recording software you should be able to record the video. After you record a video you can just find the file and double click it and what ever your default video player is it should open it and there you should have what you are looking for.
    Jun 10, 2008 | Microsoft LifeCam VX-6000 Webcam
    S-video output
    Hi
    Normally, you can use the Fn+F8 keyboard shortcut to switch the video image to the display only, the display and
    external monitor simultaneously, or the external monitor only. Unfortunately, the Fn+F8 only works with the VGA
    external monitors, not with composite/S-video monitors on Latitude C610
    I have not tested this but give it a try. It should work if you have correct Video drivers (Manufacture drivers and
    not Microsoft drivers) installed.
    In Windows XP:
    Right click Desktop and choose Properties,
    Click the Settings tab, and click Advanced
    -or-
    Go to Start > Control Panel > Appearance and Themes.
    Under or pick a Control Panel icon, click Display.
    Click the Settings tab, and click Advanced.
    Click the Displays tab.
    Click the upper-left corner of the TV button to enable the TV.
    Click OK.
    Mike
    Apr 12, 2008 | Dell Latitude C610 Notebook
    Unable to find out how to take photos on the packard bell laptop
    If you have QuickPlay installed on your lap.
    1). Run this application
    2). Click on Music/CD/Camera icon
    3). Double Click on your web cam from list
    it will open your web cam, the light of cam wil lit
    4). Click on Camera icon on bottom
    it will take your photo
    Note: if you want to record Video then click on CD icon instead of camera icon. To stop video recording click on stop button.
    Thanks
    Iqbal
    Mar 11, 2008 | Computers & Internet
    Problem with macally icecam
    1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
    2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
    A new Save window will pop up, set up the filename and location and click SAVE button.
    Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
    If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
    Dec 25, 2007 | Macally IceCam Personal Web Camera
    Kodak S100 Webcam Logo
    71 people viewed this question
    Top Kodak Computers & Internet Experts
    Andrew Taylor
    Andrew Taylor
    Barry Boyd
    Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
