Question about Dishwashers
The washing cycle does no proceed automatically however it does so when the dial is manually advanced. What could be the problem and how to sort it?
    Novelist:
  • 144 Answers
Sounds like the drive inside the timer switch. There is a timer motor that causes the timer switch to progress through the stages. When you manually progress the timer, it is physically turned to the next position and the switches all work as designed; it's just that the motor is incapable of doing that job for you as it should.
You need a new timer.
Posted on Mar 19, 2011
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
I have a whirlpool Model RAS7233KQ0 and it wont spin automatically
Possible that the timer module is faulty and there is no switching when the cycle proceeds to the spin mode.
Please check the timer module for any loose connection or dry joints on the module.
Jan 15, 2013 | Whirlpool Washing Machines
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
