Question about Poulan P4018 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw With Case
Poulan P4018 need to reassemble brake/clutch but how? Thanks
  • sjbbunn Mar 20, 2011
    How do I reassemble the brake?
  • Poulan Master
  • 2,239 Answers
This machine has an inboard brake, there are no parts available for this brake, it is not easy to re assemble the spring, and load the brake, as this is sold as an assembly, and is a main safety device, i would suggest you just order up a new brake and refit, the part no. is 530071893 if you wish to rebuild it let me know and i will try to explain how its done.
Posted on Mar 19, 2011
  • Andrew White Mar 20, 2011
    To reassemble the brake, refit the band into the houseing, use a suitable tool to compress the spring, use a pair of long nose pliers, push the unopened jaws into the end of the spring,once inside the spring it will stop it flying out and causing injury, once the spring is back in the houseing re fit the securing clip, to re fit the brake and load it you need to remove the clutch and sprocket, the sprocket is held on with a simple c clip, however there is a special tool to remove the clutch 530031112, this tool fits into the two cut a ways in the clutch centre, with a 19mm nut on the top, this allows you to jar it off against compression ( left hand thread ) it may be possible to make a tool for this purpose, once off the brake will now re fit onto the crankcase, and using the hand guard load the brake.
POULAN RIDING MOWER. CRANKS BUT SHUTS OFF WHEN YOU LET OF BRAKE/CLUTCH
You have a bad safety switch. It is either the seat switch or clutch / brake switch.
Apr 25, 2014 | Poulan Garden
I am unable to get the bar and chain off of my Poulan Pro 260 42cc chainsaw because the stud for the clutch brake housing has broken loose inside the housing. When turning the clutch brake nut the clutch...
I ran into the same problem and I "cheated" my way through this. First of all, the thread is metric on the stud. Take an imperial nut and start to thread it on the stud. Don't force it, it will stop after half a turn. Now you hold the imperial nut with a socket or a wrench, and use a flat wrench to undo the other nut(the one that is stuck). It took me 2 minutes to remove it and no damage done at all.
Hope it helps
Mike
Jun 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Unable to release chain brake on Poulan 2150 2.1c.i. Unable to reassemble the chain brake cover.
You should have released the chain brake before removing the side cover. Try using a wide, heavy, flat-blade screwdriver to release the toggle mechanism for the brake in the outer cover which should expand the brake ring to allow it to go over the clutch drum. Hope this helps!
Nov 03, 2010 | Poulan Garden
I need to know how to replace the sprocket on poulan model 4620 chainsaw
A link to a Poulan "PP4620AV Gas Saw” follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4620AV-Gas-Saw/75.PP4620AV-Gas-Saw.1.59.1.html
If not your model number all IPLs can be found here:
The IPL (exploded parts list) for your saw is beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The 4620 link has an outboard clutch remove it as demonstrated here (chain brake must be released else difficult to remove the clutch cover and impossible properly to reinstall):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 10, 2010 | Poulan Pro Chain Saw 46cc 20"
How to repair Poulan Pro PP4018 with a bad clutch?
Hello Paul;
A link to a Poulan "PP4018 Gas Saw Type 2 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4018-Poulan-Pro-Gas-Saw-Type-2/75.PP4018-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
If yours is not a "Type 2" all IPLs can be found here:
Poulan.com
The 4018 link has an inboard clutch the drive link is changed as demonstrated here (chain brake must be released else you cannot remove the clutch drum):
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
If the actual clutch needs replacement continue with the remaining pieces as follows (IMO if changing the actual clutch the bearing should be replaced too):
Lou
May 10, 2010 | Poulan Garden
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Jammed pull cord on Poulan P4018 chainsaw!
There maybe a split pin holding the cover down over the spindle! Not too sure, but possible. Could be pushed down the centre, just a case of having a good look. Only really worked with Hurqvarna's and Makita's. Hope it helps. Good Luck
RICH
Dec 16, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Chain runs constantly how do you ajust the clutch or brake
It sounds as though the saw may be running to fast (centrifical clutch engaged) or the clutch springs are tired or broken.
Do this to inspect the clutch. Remove the drum and clean the interior while there.
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
There is also an idle adjustment for your saw too, the one seperated from the others. Often marked as T (throttle). GL
Lou
Oct 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I just took apart the brake mechanism on my poulin
The only known illustration for a Poulan 2375LE is here:
Poulan.com
It appears they want you to purchase the entire clutch cover. There is no specific detail.
Type 1 pn530054740 item 39 $19.43
Type 2 pn545139903 item 36 $19.43
There are other than 2375 Wild Things.
Go here for additional help identifying your saw. Please have it within easy reach if telephoning.
http://www.ordertree.com/cms/Contact+Us/6.html
HTH
Lou
Oct 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan P4018 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw With Case Logo
180 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
