Question about Dishwashers
After washing the dishes are not clean. There is a white film over-all. Our water is "hard." I have had this dishwasher several years.
  • 1,606 Answers
Check your rinse agent dispenser and fill it if it is empty. If it is not working or you can't find one, you can buy solid rinse agent balls - just hang one in a dishwasher rack and leave it there until it is used up. I have had good results with both Jet-Dry ® and the Wal-Mart store brand - the film came off of my dishes on the next wash after I refilled my dispenser.
Check the holes in the spray arms for clogs or other visible foreign material. These are generally made to be removed without using tools (hand-operated threaded nuts) so you can clean out any garbage inside them.
Check the owner's manual for your model. There may be a dishwasher cleaning procedure, such as pouring a cup of vinegar into the bottom of the machine and running a short wash with no soap or dishes and a no-heat drying cycle. If you see a build-up of soap residue in the machine, you may want to do this, and cut back a little bit on the amount of soap you use.
Posted on Mar 19, 2011
    Novelist:
  • 144 Answers
It probably isn't a problem with the dishwasher.
Manufacturers of dishwashing detergents have recently been required to stop using phosphates, resulting in a lot of upset people complaining about the same thing you described.
You can try adding vinegar to the final rinse of the cycle, or you can install a water softener.
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
The dishes have a chalky residue all over them after washing. I have to use a brillo pad to remove the residue. I use Jet Dry, but it doesn't help. My water is "hard water," if that has...
heatman101
Feb 23, 2011 | KitchenAid Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
My Jenn-Air dishwasher, Model #JDB1100AWW, is now not cleaning the dishes well. We have had it for approximately 5 years and up to the last several weeks, it has worked well. Now, however, after the load...
heatman101
Oct 18, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishes not clean
Run a hot wash without the dishes and a quart of white vinegar plus detergent which should wash out any oily film left by the water folks when they were 'fixing' whatever. You may have to do this several times until the water runs clean as before. Hope this helps!
Jun 27, 2010 | Dishwashers
My dishes are getting a white powder film on them after they wash
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Mar 07, 2010 | Maytag 24 in. MDB6100A Built-in Dishwasher
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Chalky dishes in dishwasher
Are you in a location with "hard" water, meaning that the water has alot of minerals in it like calcium? If so, you may may need to get the water treated with a water softener system, either at the dishwasher or for the whole house.
Feb 15, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Kenmore dishwasher 15899100
Dennis, Im assuming your model number starts with 665. This model had a service flash on it regarding the upper spray arm. The upper spray arm has been redesigned for better performance. Part number 8269022. This could be covered by Sears if you mention the service flash, 22-714. Other issues that can lead to this problem are; water hardness, if your water is over 7 grains of hardness, this could to this film on the glasses. Try pouring 1/4 cup of Glass Majic into the bottom of the dishwasher. Also run one cup of white vinegar to clean the dishwasher. Make sure the water temp. entering the dishwasher is 120 min. to 150 degrees. Catriver..post back.
Oct 30, 2006 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
