Question about Neff R4381 Electric Commercial Dryer
Neff Tumbledryer All the electric is working but when you press start nothing happens. All the lights are on, you can select which kind of "dry" you prefer. The time comes up, but it just won't start. Any ideas
  • alliwar Dec 19, 2008
    i have the same problem. can anyone help solve this one.
  • archiejack Jan 24, 2009
    Timer display shows two dashes but dryer wont respond when start button is pressed
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Dont know much about commercial units but if it was a residential unit i would first check the door switch. in res machines it cuts the power to the motor only so every thing works but it wont go.
Posted on Nov 08, 2008
Mirowave wont start
I assume from your description that you can set power and time but nothing kicks in when you press start?? This could be a control panel fault but may be a problem with the door lock/switches. Check that the spring on the door hooks is ok, just lift it up and check it returns to down position by itself. If the microswitches do not make properly when the door is closed the m/w will not start because it assumes the door is open. A microwave (even when switched off) can be storing a high voltage so unless you are trained I would suggest you get an expert to take a look. BSH is Neff service division 0844 872 8999, they offer a one off repair plan, which covers your first repair and then any further repairs for a year. You can pay monthly by DD to spread the cost. (This may be age related so as yours m/w is nearly 10years old, it may not be eligible).
Hope this helps.
Mar 21, 2013 | Neff Microwave Ovens
Whirlpool wed5840sw0 dryer NOT STARTING
not make for large blanket change the white fuse air not going out
Nov 13, 2017 | Whirlpool GEW9250 Electric Dryer
Whirlpool model KUDSO1FL not starting cleaning
I fixed the problem by hitting Hi-Scrub then Economy Dry in sequence four times in a row. All of the lights came on, I am assuming to reset it the program, then went off and the start button was highlighted. I then pressed cancel and then selected the program that I wanted to wash with and pressed start. It worked like a charm.
Jan 31, 2010 | Whirlpool Dishwashers
Motors starts but nothing else happens
Hi
There should be some kind of button and an handle both should be pressed and only then the blade should rotate .
Thats the way it works in my electric lawnmover i guess it more or less the same in all of them .
hope it helps
Jul 16, 2009 | Black & Decker 19" Electric Lawnhog...
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
2003 megane won't start
dump it its a renault,dealer only encrypted software
Nov 17, 2008 | 2003 Renault 181
U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
Jul 06, 2008 | Neff U1721 Double circotherm Electric Oven
LG DLE 9577
check to make sure that the power legs are correctly installed.  Use an volt meter and measure voltage across neutral and hot.  Hot leads should be on the left and right side and neutral is in the middle.  Hot to neutral should be 120v.  Hot to hot should read 240v.
Feb 06, 2008 | LG DLE9577 Electric Dryer
Hotpoint condenser tumbledryer
Check the amp use of your dryer and compare it to the fuses.
If the dryer is taking more amps than your fuse can dish then it will blow. Upgrade your fuse and/or breaker to a higher amp rating.
Nov 06, 2007 | Dryers
Neff R4381 Electric Commercial Dryer Logo
420 people viewed this question
Top Neff Dryers Experts
gbob59
ray gallant
Nicholas Tipples
Nicholas Tipples
Level 1 Expert
Are you a Neff Dryer Expert? Answer questions, earn points and help others
