Question about Speed Queen Washing Machines
The pulley below the tub chatters loudly as it bounces up and down. Speed Queen AA5421. Replaced the belt as I thought that was the problem as the old belt was cracked in places all around it.
  • 1,606 Answers
The pulley bearing is probably worn out. Also, check the pulley arm pivot bearing for excess play.
Posted on Mar 19, 2011
I had my speed queen about ten years it washes properly when it come to spin it go very slow and with jurking movements what can be wrong please
Open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
My problem first started with my maytag LAT9416AAE making terrible sounds and the smell of burning rubber. We replaced the belts that were loose and thought that fixed it. Now it is leaking water unde
Tub seal should take care of the leaking water sounds like you have a bad spin bearing from the water leak this will make a loud noise and put a drag on the basket trying to spin this will cause the belts to slip giving you the burning smell since you have it torn down remove the lower pulley lift out the transmission and change the bearing below it this is the spin bearing.
Jan 18, 2014 | Maytag Washing Machines
Pulley bouncing
take the belt off and check the pully for play
Apr 25, 2009 | 1997 Buick LeSabre
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Amana lw8203w leaking
Your LW8203W is at least 12 years old. It is leaking from the tub seal, Your machine needs to be rebuilt or replaced.
If you have it rebuilt I would also put in a new belt, pump, brake pads, upper tub bearing and the tub seal it needs.
Call and authorized Speed Queen or Amana dealership and ask for a price quote over the phone. Then price out a new machine.
Your choice.
Jul 05, 2008 | Washing Machines
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Belt
We'll assume no problems with the belt installation - the tensioned idler pulley is pressing against the belt etc.
You didn't say whether it drained out OK or specify what model but it sounds like the brake is stuck or there's something caught in the basket. Try turning the main drive pulley (the one in the middle) Even with it full of water it should turn freely. Take the tub top off and check for foriegn obects stuck between the basket and outer tub. A wire coat hanger works well fro this.
Jan 04, 2008 | Speed Queen AWS75NW Top Load Washer
Speed Queen wash machine
may be incorrect belt or gear box locking up.
BELT REPLACEMENT
look real close in the tub holes to see if a small object like a nail or screw is jamming it then try to turn the tub by hand and let me know the results
Dec 30, 2007 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Speed Queen Washing Machines Experts
Charles T Nevin
Charles T Nevin
fta777
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
