Question about Technics SC-DV290 System
I cant set up my speakers to my hifi - Technics SC-DV290 System
    Genius:
  • 1,622 Answers
Hi, you can use the manual for guide on how to set it up..
http://tda.panasonic-europe-service.com/docs/2z4d852d61z3z1fd79z656ez706466z22z933b33d8bf0d55d5e5d2da6adc6f3a94575d8c31/tsn2/data/ALL/SCDV290E/OI/736855/rqt6894-b.pdf
Posted on Mar 19, 2011
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
HOW TO HOOK UP Technical Hifi LZ-2000 amplifier
you need to say how you want to wire it up.is it to speakers that will be bi-wired or just a normal set of speakers,if its a cd player you want to play,how many sets of speaker terminals there are at the back of the amp.tell me exactly what the problem is in as much detail as you canand i can help you easily.
Jan 07, 2013 | Technical Hifi PA2000 Amplifier
I wired a set of mission 700 speakers to a tecnics hifi and now it wont come off stand by what could be wrong.
The way you say "a" Technics hifi implies the SCEH790 might not be the model.
Whenever you DO something and a malfunction appears, UNDO it to get back to square one.
UNwire the speakers and see how that works out. OR you shorted the speaker wires.
May 30, 2011 | Technics SCEH790 CD Shelf System
Hi i have a set of 203 JPW floor standing hifi
remove grill and approximately 6 to 8 screws hold speaker to box. Follow appropiate wiring in removal as replacement. Check crossover while you have it appart
Mar 08, 2010 | Sony MHC-RV888D Shelf System
Crackling sound on my amplifier
If you have good clean, loud sound with your LP player and not with your PC, your PC is causing the noise. Most PC sound cards are not very HiFi in their sound and it is quite evident when listening to a PC via a HIFI sound. Now, you can not use the headphone outputs to your Pioneer, you must use the LINE OUT jack, set as line out in your computer. There is a signal level mismatch if you use your headphone outs, distorting your Pioneer. Try LINE OUTs or buy a HiFi rated sound card.
Feb 23, 2010 | Audio Players & Recorders
I am trying to run the sound from my Packard Bell imedia x4520 computer through my Hifi amp. I think I have followed all the links on the PC regarding setting up the realtek sound for setting up external...
It sounds like the 3.5 plug is mono or the plug is not completely inserted in the computer jack (push it in until you do not see any more of the contacts). I connected one of my computers to my stereo receiver and used a splitter so I could use both my computer speakers and the stereo without disconnecting any cables. First make sure your 3.5 jack looks like the one in the link with three contacts and two insulators (the black plastic piece).
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40421#
If you see only one insulator and two contacts it is mono and the second channel will be shorted out.
I would recommend using the Front Line Out which is a pre amp output into your auxiliary input on your home amplifier. If you use the headphone jack you may have clipping of the signal causing distortion.
Use the cable similar to the one in the link below or you can purchase one at Lowes or Target.
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40427#
Plug the splitter male jack into the into the computer Front Line Out and the computer speakers into one female jack.
Second connect an 3.5mm to RCA stereo patch cord to the other female jack of the splitter. If you have a 3.5mm to RCA mono purchase one similar to the link below.
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40613
Jan 25, 2010 | Packard Bell Speaker Computer Speakers
Can i connect extra speakers to my hifi unit if
to be honest i dont think it really matterys what impdance the speakers are just connect the new speakers in parralel with the old ones
(positive to positive and negative to negative)
Jan 14, 2010 | Audio Players & Recorders
Technics sa dv280, input selection
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
Jun 25, 2009 | Audio Players & Recorders
RIGHT HAND SPEAKER, DISTORTION.
First switch the speakers over to make certain it is not the amp that is the problem.
If the speaker is still playing up on the other channel, then I would look around at a new set of speakers. They can be any that you like the look of as long as they have a power ratting at 40 watts or above each. The amp says it can take 6 to 16 ohm speakers. I would go for 8 ohms as they are more common.
Jul 03, 2017 | Kenwood NV-600 CD Shelf System
Cleaning hifi speakers
unplug set. Clean gently with a thin brush
Nov 08, 2007 | Toshiba 46HM95 46" HDTV
Technics SC-DV290 System Logo
94 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
