Question about Sharp Televison & Video
The power button is missing and i am trying to program a universal remote to this tv, but i can't turn it on yet. The cable technical support people know how to turn it on without a remote but I don't know how, do you know how I can turn it on?
    Problem Solver:
  • 9 Answers
If the button has simply fallen off of where it used to be, you can use a pin or other small object to push the area inside where the button was, where the button itself would have pushed if you pressed it. Very similar to if a laptop key falls off and you have to hit the small rubber nub that the key itself used to hit.
Posted on Mar 19, 2011
I have a jvc 32inch tv and the on and off power button is missing i cant turn my tv wont turn on or off i bought a universal remote and my tv is still not coming on
Program the universal remote following the instructions manual for that model TV. Usually holding the power and TV button until the TV power light comes on. Or, try the combination codes for that model TV.
Nov 25, 2014 | Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
Need code to program rca remote to my rca t.v.
rca technical support is sadly lacking... I used youtube to search for the remote model number to find a video that taught me how to search with the remote to get the proper code. ..try this, for tv hold tv button and power button on remote till power button turns red, next point remote at tv which is already on and press the play button on the remote. This causes the remote to try 10 codes. wait for the power button to quit winking at you, if the device (tv) turns off, it means that one of the 10 codes was correct. If the device stays on press play again to try the next set of 10 codes. It may take several tries. When it responds by turning off, we need to back up to the exact code by pressing the << reverse button one press at a time. When power comes on you have found the code. Now use the stop button to lock it in.:) I'll include a link to a vid. Programming an RCA Universal Remote If this helps please 'like' my answer.:P Mikee
Oct 13, 2014 | Televison & Video
I am trying to program an 8820 cox remote with my olevia tv
Not suprising===not all programmable remotes if they will even program will have all essential features---universal is a misnomer.
Jun 11, 2012 | Olevia LT27HVX 27 in. LCD Television
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Need help programming a universal remote
make sure you have AV button activated......looks to me ur son pushed TV .......if so just push AV on ur set and all will work again.....if u cant find it on ur set ,,, it will be on ur remote control
Jul 03, 2009 | RCA Universal Remote Control
Missing power button
there is one thing you can do cheaply,
open the tv by pass the switch, put straps a cross switch contacts.
only two polarities enters your tv live and netrual, each one goes a cross the switch.
program your remote
0156,0060,0154.
or 060,019,014,052,054,075.
Jan 22, 2009 | Toshiba 35A44 35" TV
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Jun 24, 2008 | RCA Universal Remote Control
RCA Universal #RC402A
Jun 21, 2008 | RCA Universal Remote Control
Televison & Video Logo
41 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
