Question about Sub-Zero Refrigerators
Subzero 424 Not cooling. Not sure all connectors are connected. Have two sets of connectors besides the alarm set that are attached to nothing.
3 Suggested Answers
  • 71 Answers
SOURCE: subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Posted on Apr 03, 2010
  • 9472 Answers
SOURCE: my subzero 424 wine refrig
Here is the complete manual for your unit. On page 10 it has the information for the temperature settings.
Posted on Feb 06, 2011
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
My sub-zero 424 is having temperature control problems, maybe. Our A/C is out in our home as well, and the ambient temperatures are above 75 mid-day. When this happens, the temperature rises also in the...
first clean the condenser coils if you haven't.
At the bottom of the unit, remove the screws holding the kick plate.
probably black with vents.
The coils are behind that use a soft duster or a vacuum with brush attachment. swipe in the direction of the coil fins.
If they were dirty that's more than likely the problem.
Hope this helps...?
Jan 10, 2018 | Furniture
Subzero Model 424 Service Light ON - Codes: 10EC, 15EC, 73UE, 73LE, 73UP, 73LO. No codes are EE.
an "EE" code means you have an open thermistor. "EC" is a extended compressor run code. typically with the 424 if the thermistors are good, as in no "EE" codes you probably have a refrigerant leak. 73UE is the temperature at the upper evaporator thermistor. 73LE is the temp at the lower evaporator thermistor, 73up is the upper compartment temp and 73lo is the lower compartment temp. the unit probably has a leak in the evaporator/heat exchanger assemblies and needs a refrigeraton system rebuild
Feb 28, 2013 | Sub-Zero Refrigerators
2005 Jeep Liberty overheats at idle but while in movement temp returns to normal.
Check to see if the fan on the radiator is working at idle.
Here's information on how to change the fan if needed:
Engine Cooling Fan Removal & Installation 2.4L Engine To Remove:
  1. Remove the coolant bottle and set aside.
  2. Remove the power steering reservoir and set aside.
  3. Disconnect the cooling fan connector.
  4. Remove the cooling fan mounting screws and the cooling fan.
To Install:
  1. Install the cooling fan and the mounting screws. Tighten to 50 in-lb (5.5 Nm).
  2. Connect the cooling fan connector.
  3. Install the power steering reservoir.
  4. Install the coolant bottle.
3.7L Engine To Remove:
NOTE: If the fan blade is bent, warped, cracked or damaged in any way, it must be replaced ONLY with a replacement fan blade. DO NOT attempt to repair a damaged fan blade.
NOTE: For 3.7L Heavy Duty/Max Cool/Trailer Tow cooling package, the viscous fan cannot be removed separate from the shroud. Both fan and shroud must be removed together.
  1. Disconnect battery negative cable.
  2. Using special tool #6958 spanner wrench and #8346 adapters, remove the viscous fan from the water pump.
  3. Gently lay fan into shroud.
  4. Disconnect the electrical connector for the electric fan, then disconnect connector from shroud.
  5. Remove the two fan shroud mounting bolts connecting the fan shroud to the radiator.
  6. Remove the shroud and fan from the vehicle.
To Install:
  1. Install fan shroud assembly into the vehicle. Tighten fan shroud to radiator bolts to 50 in-lb (5.5 Nm).
  2. Install shroud mounting bolts tighten bolts to 89 in-lb (10 Nm).
  3. Connect fan motor wire connector to harness connector, and attach connector to shroud.
  4. Connect negative battery cable.
  5. Start engine and check fan operation.
Aug 31, 2010 | 2005 Jeep Liberty
Subzero does not cool sufficiently, even with cool
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
I bought an unlocked G1, Im in the UAE, how can I set up my phone it is not connecting to the 3G network of etisalat
Here is how to set G1 3G and MMS for UAE Etisalat separately (u can enjoy mms or 3G alone by deactivating settings for either one). First you need to setup 1 access point for each service, sttings is as follows:
Name: Etisalat3G (could chos any name)
MCC: 424
MNC: 02
APN type: default
Name: EtisalatMMS (chose any name)
APN: mms
Port: 8080
Username: mms
Password: mms
MMSC: http://mms/servlets/mms
MMS proxy:
MMS Port: 8080
MCC: 424
MNC: 02
APN type: mms
Enjoy the ultimate G1 services!!!
Feb 20, 2009 | Google Android
Two sets of power leads to motherboard from pwr pk, 1 x 20 pin and a 4 pin, when the 4 pin isn't attached to the 8s651mp-rz motherboard the fans spin, the mother board light comes on, but then does...
The 4 pin connector is required as it provides the power for the CPU to run. if nothing is happening with the 4 pin connector plugged in then there is a problem. You need to make sure that you Power Supply can supply enough power for what you are connecting to it (400W would be the bare minimum with no high end video card, 500W would be recommended). You also need to make sure that the Power Supply is connected properly because some Power Supplies from pre-built systems from companies like Dell are wired differently than the standard power supplies. The only other likely problem is that there is a short on the motherboard either from the mounting of the motherboard in the case or from something on the motherboard being bad. Make sure there is no metal touching the motherboard except at the holes used for mounting.
Jan 02, 2009 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Refrigerators Logo
169 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
