I have a kichler ceiling fan model 35015 and cannot find a switch to reverse the direction of the fan so that it will blow down.
  • 2920 Answers
SOURCE: 56 altura ceiling fan only
there is a switch on the fan itself you can use to change the direction of the fan
Posted on Aug 20, 2008
SOURCE: reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Posted on Nov 30, 2008
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Posted on Apr 30, 2009
  • 630 Answers
SOURCE: ceiling fan does not blow air
I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
Posted on Sep 19, 2009
  • 4 Answers
SOURCE: my ceiling fan has no reverse switch, how do i
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Posted on Sep 24, 2009
Why does my ceiling fan always start off blowing air up instead of down?
fan direction control faulty
normally is a switch above the fan but if remote controlled could be the remote problem
Feb 05, 2018 | Dryers
Why doesn't ceiling fan reverse?
Putting the fan in reverse is done by mechanically reversing the leads powering the motor. All the wall switch does is supply the power and the fan circuits take care of the speeds and direction.
Your problem is with the fan reverse control and/or electronics.
Sep 08, 2015 | Dryers
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 | Dryers
Rhine ceiling fan remote replacement
Where did you find the little black box?
Apr 16, 2014 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
Ceiling fan won't blow any air
if its turning its either sucking or blowing air. There is a switch or a pull cord to reverse it. prove it to yourself with something light like a feather or piece of paper or balloon.
Aug 16, 2009 | Hampton Bay 24750 Huntington III Ceiling...
I have found the right solution to the fan not working in the right direction. the problem is that is a pcs of trash, i ripped mine off the ceiling and tossed it out the window and guess what it, it flew...
Did you hit the reverse direction switch located on the upper fan body. Upward direction is for winter as it blows up toward the ceiling pushing rising heat out towards walls and down to floor. Downward direction sucks heat off ceiling (summer months) and pushes cooler air that is on the ground toward the ceiling, thus giving a cooler airflow. You do know that there is a little black switch up there, right?
Feb 28, 2009 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
