Question about Panasonic SCPT480 Theater System
I am trying to hook up the panasonic sc-pt480, and we can't get the cable sound to come through the system, all other functions workwell
  • 604 Answers
Try plugging the cable sound outputs (red and white plugs) into the other inputs that work on your amp to make sure that you are getting sound from the cable box.
Posted on Mar 20, 2011
My Panasonic surround sound system SC-PT480
Defect can be a switch (contacts / soldering or wrapps) ,or a fuse caused by a shorted rectifier bridge component or 1 diode in the bridge of 4 pcs , a shorted voltage regulator or shorted power mosnfet in the power supply. caused by a bad capacitor or soldering.
DVD Home Theater Sound System
Jul 16, 2016 | Panasonic Office Equipment & Supplies
How to hook up my cable box and tv to panasonic sc-btt190
You could have a bad Hdmi outlet . Try hooking up component c what happens
Dec 19, 2012 | Panasonic Sc-Btt190 Home Theater System...
I cant get my tv audio to play through my sc-pt480 unit.
check if the audio cable is working to another audio system or try another input option to your Panasonic HT system
May 21, 2011 | Panasonic SCPT480 Theater System
I need to reprogram the remote. Purchased a floor model Panasonic SC-PT480 and the remote is not fully synched with the player (controls on/off and volume only). How can I reprogram the remote?
The remote cannot be reprogrammed to operate the SC-HT70 as all functions are already set. If your remote isn't operating your equipment as expected then the chances are the remote has become faulty.
The remote can be programmed to operate other equipment as detailed on Page 42 of the manual below.
http://service.us.panasonic.com/OPERMANPDF/SCHT70.PDF
May 01, 2011 | Panasonic SC-HT70 System
I am trying to connect my Panasonic sc-pt480 to my desktop is this possible
Yes. Each should treat the other as an audio device within the unspecified sound capabilities of your PC. Get it? A sound card is no different than any other audio device except you have software controls that need to be set to us its inputs and outputs.
Apr 26, 2011 | Panasonic Home Theater System System
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
I am trying to find an update driver for my Panasonic DVD Home Cinema SC-PT450-K Can you help? Plus how o I upload a DVD player with these drivers?
Hello
According to panasonic they dont make a pt450 but they do make a 480, so I assume this will get you close enough.
here is the driver site
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/Drivers-Downloads/model.SC-PT480.D#ts
Best of luck
PS you can also download the manual too, and that will give you all the directions.
Nov 27, 2010 | Panasonic Televison & Video
I hooked up my SC-PT480 and there is no sound
make sure you have selected the audio input with the input selector.The audio input where you plug in your audio player must be the input you selected by the input selector
Sep 10, 2010 | Panasonic SCPT480 Theater System
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Panasonic SCPT480 Theater System Logo
129 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
