Question about Canon PowerShot S51S Digital Camera
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail. Can you help me? Thank you!
  • 2,574 Answers
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Posted on Mar 19, 2011
Got a new memory card for my camera and im getting an "Out of Memory" warning
Most digital cameras will work with only with specific memory cards. You can't just buy any old card and expect it will work in your camera. Approved cards for Nikon E5700 are listed on page 159 of the English version manual. (In the Technical notes.) Also, if you insert or remove the memory card with the power on it could render the card unusable and, of course, you must insert the card in the correct orientation.
I assume you have not taken a heap of images in high resolution and simply filled your new card.
Sep 09, 2011 | Nikon Coolpix 5700 Digital Camera
I took my memory card andput it in the laptop, then it said "import pictures" i clicked yes...then my friend said "wait no!" no i exited the little import box. now when ever i put the...
They're still there, except the card has become corrupted, and is not readable by your camera. See if you can insert the card back in your laptop and save the pictures onto your computer. If your laptop doesn't recognize the card either, then you may need to use recovery software. In that case, see the corrupted card procedures in this link. Once you successfully recover your photos onto your computer, you'll need to format your card IN YOUR CAMERA to make it usable again. Finally, sorry but if you were intending to use the card to long term store your photos and display them using your camera, you will no longer be able to do that with the previously taken photos.
Jul 11, 2011 | Cameras
The camera repeatedly tells me to format the 4GB card that I have inserted. It reads, "formatting," then returns to "Memory card requires formatting." Selecting "Continue"...
The DX6440 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Dec 27, 2010 | Kodak EasyShare DX6440 Digital Camera
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
Dec 19, 2010 | GE C1033 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Kodak C533 Digital camera. Says "Internal Memory Full". Have deleted all pictures & have taken less than 300 pictures since the camera was new. How can it be full so soon & how do I fix...
The internal memory, as opposed to any memory card you may have inserted, is quite small. The fix is to use a good sized memory card, or maybe a couple when you are on holiday, so you can fill one and then put in a new empty one, like people used to change films.
Nov 21, 2010 | Cameras
Hi, My Nikon D90 with Nikkor 18-200mm lens is giving me the following error message: Memory card is locked. Slide to "write" position. Any ideas how to correct this? Thanks! Jennifer
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
Nov 20, 2010 | Nikon D90 Digital Camera with 18-105mm...
My Nikon Coolpix S8000 will not turn on. I started using it for the first time this morning and took about six pictures with it, then I removed the memory card in order to upload the pictures onto my...
Make sure you insert memory card correctly, when it is fitted into the memory card terminal it give clicking sound. Second thing you can check battery, Direction of your battery might be wrong (+,_), Check out and put it again. Load new or fully charged battery. Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
Else your camera need to be repaired.
Thanks...!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Nikon COOLPIX S8000 Digital Camera
No Memory Card
Double check the position of the memory card's write protect tab - it should be slid away from arrow pointing at the lock position. If this is OK and the camera is brand new and can be easily returned to the place of purchase, do that and ask for them to correct the problem or replace the camera/card. If returning the camera is not an option, try cleaning the contacts on the memory card itself- a pencil eraser works well for this purpose. Be certain to clean any eraser crumbs from the memory card before inserting it back into the camera.
Sep 25, 2009 | Cameras
Can not view pictures
No this camera does not have any internal memory. All images should be written to the memory card if the memory card is inserted properly. If the memory card is not inserted correctly the camera screen will show a message of No card. Do you see that message?
Apr 27, 2009 | Olympus E-520 Digital Camera
Canon PowerShot S51S Digital Camera Logo
753 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
