Question about Lasko 2152C Hassock Floor / Box Fan
BROKEN BLADE MY FAN HAS A BROKEN BLADE
  • 19,396 Answers
Replace Fan, order part from Lasko
Posted on Aug 03, 2008
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Can I buy only fan blade? My one got broken
All of the fan blades are one piece along with the hub which is attached directly to the motor pulley (if fan is like the fan which is pictured).
This is true even if there is some kind of attachment between each blade and the hub -- it comes as one piece.
If you can purchase it, or another which will function like it, there are two places you may go to: 1) Sears sells parts for everything they sale. If you didn't get your fan from Sears, then you can still go to Sears and possibly locate a fan which is close enough. 2) Appliance parts stores (like A&M Parts/Johnstone supply) sell fan blades.
Before you begin, remove the broken fan blade (including hub). Matching the diameter and pitch of the blade and the hub to motor attachment is the goal. It can only be of good to know the make and model, but it is not necessary.
:o).
Jun 04, 2011 | Lakewood 16" Stand Fan
A broken blade on our Hampton Bay Brushed Nicel Romano
you can call air cool, they manfacture and service the fan. 800-896-4908 price as of 7-12-10 was $12 per blade and $30 for the set of four. manual is $5 as well
Good Luck
Oct 22, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
The Fan on my a/c unit isnt turning. Whats wrong with my a/c unit?
check power supply, check supply circuit fuses, if all good trace wire to fan motor itself check for current, if voltage is present check ground circuit for open.. if all checks good fan motor is bad or fan blade splines are stripped cause motor shaft to spin without fan blade turning, have also seen where a pencil, paper clip debris has broken fan blades when people store stuff on top of dash board panel , debris falls into vent back into fan housing resulting in a broken fan blade... check all
Aug 04, 2009 | Heating & Cooling
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Fan blade for a U2-20
I have a metal blade for the Patton U2-20 fan listed on ebay. The item number is 160273949463 and the listing ends on Wednesday August 27 at 10.00 p.m. I had this fan for 8 years and the motor has failed. Patton could not replace the motor since this is a discontinued item, and I figured that someone could use another blade for their fan. I hope this helps you!
Jun 27, 2008 | Patton Electric U2-20 Box Fan
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
How to remove and install fan in freezer compartment of GE side by side
Most of these fans have a small dowell pin that goes through the fan blade sleeve and through the shaft look for a pin on the side of the fan blade sleeve then you will need a pin punch to push this pin through. After you do this save the pin or dowell because you will need it to attach the new fan.
Jun 03, 2008 | Refrigerators
Lasko 2152C Hassock Floor / Box Fan Logo
612 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Shehu Pro
Shehu Pro
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
