Question about Samsung SL102 Digital Camera
Card locked comes up. can't take any pictures. what to do...
  • 2,574 Answers
There is a lock button on the memory card check it if it is SD card or camera might not support the card
Posted on Mar 19, 2011
Card locked comes up can not take a picture
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2014 | Vivitar ViviCam 8400 Digital Camera
I try to take a picture and this comes on the screen write protect.
This is a common problem with SD & SDHC type memory cards - and is easily fixed.
Remove the card from the camera and inspect the edge for a sliding tab and lock indicator.
690144df-2144-46c7-9b90-dd85c207a09b.jpgYou can see the tab & lock indicator on the left side edge in the picture of the front of the card above. Slide the tab UP - away from the lock position - as shown in the picture. The card is now able to be written. When the tab is in the lock position, the card may only be read.
Carefully reinsert the card into the camera - taking effort to see that the tab is not bumped / moved back into the lock position. You should be able to take pictures and have them saved to the card - without the locked message from this point on.
I hope this helps & good luck!
Aug 02, 2013 | Canon Rebel XT / EOS 350D Digital Camera
When i insert my fujifilm 2gb memory card into model jv100 all i can do is look through my pictures i cannot delete or use anything else ,and a icon comes up in the centre of the screen when i look at my...
A few things but the first that comes to mind is that there is a little slid lock on the upper left side of the memory card. This lock needs to be pushed forward towards the gold contacts to unlock the card. Another problem could be tat the 2gig card is full of pictures and needs to be downloaded to your computer. Once this is done the card will need to be formatted to clean the old pictures off and make the card ready for new pictures. I suspect when you take this card out (2gig) the camera defaults to internal memory and yes everything will work as it should until the internal memory is full of pictures as well
Dec 24, 2010 | FUJIFILM FinePix JV100 Digital Camera
Card locked
If this happened after the card had been removed then you may have inadvertently slide the card lock into the 'lock' position. If the card has not been disturbed, the very fragile 'switch' may be defective. I would try removing the card and operating the slide-lock several times and then leaving it in the unlocked position.
Jun 18, 2010 | Canon Cameras
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
Samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 26, 2009 | Samsung Digimax 4010 Digital Camera
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
Jun 10, 2008 | Samsung Cameras
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
Sandisk is On card lock???
The card probably needs to be formatted for your camera but that will erase the pictures already on the card. Far as I know each card must be formatted to the camera for which it is to be used. Use the menu button to find format. (Last icon, "wrench2", format is toward the bottom of the list. Remember you will lose the pictures already on the card, so save them first.
Aug 02, 2007 | Samsung Digimax S630 Digital Camera
Samsung SL102 Digital Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
