I have a Philpps flat screen TV. While watching TV it just clicked off and wont come back on. There is a red flashing light in the lower left hand corner. There has not been a power serge so it cant be that.
SOURCE: red light flashing 6 times
hold down the power button on the remote until the light turns green then it will come on.
Posted on Aug 31, 2008
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
Dynex big screen tv stopped working won't come on with the remote of the botton. Only a little over a year old
The same exact thing just happened to me. I was watching tv and it just turned off by itself and now it wont turn back on. I've also only had mine a little over a year. The red light is on at the bottom left hand corner, but it wont turn on at all. Hopefully we can find an answer to what is going on!
May 21, 2010 | Protron PLTV3250 32 in. LCD Television
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Nov 03, 2008 | Televison & Video
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
May 13, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
