I have an OLD Underwood (non electric) tyrpwriter and don't how to install the two reel ribbon...please help...
  • 3,594 Answers
First determine which way the ribbon turns most wind to the outside but a few wind to the inside. Put the ribbon on the posts so it winds properly then put it thru the reversing arms. then thread it thru the lifter you'll have to figure that by yourself as there many different set ups.
DickyO
Posted on Mar 21, 2011
Olivetti Underwood Studio 44 ribbon won't advance.
Remove the top cover, remove ribbon spools, press a key and grab it with your finger, note the mechanical motions toward the ribbon advancer movement, usually found near the center of the ribbon holder or could be on the outside edge also, there is a reverser mechanism also that should be fully to one side or the other, it switches the ribbon direction to avoid a 'dead end' while typing. By moving the key toward the platen and away it should drive the ribbon mount spool by a shifting drive lever of some kind. If you cannot resolve this issue, take it to a rare typewriter repair shop, it is too hard to explain in this format, and mechanical skills are involved, hope you have them, ;)
Sep 14, 2013 | Underwood Retro green Olivetti Studio 44...
Which typewriter ribbon do I buy
If the spools are 2" in diameter have a 1/8" hole in the center with 4 or 5 smsller holes around it this is a pretty standard fabric ribbon we have them in stock if it is different sem\nd the spools to us and we will wind a new ribbon on them.
DickyO
216-269-3918
Jun 17, 2013 | Olympia Office Equipment & Supplies
How do you remove carriage on an underwood 565 typewriter
You don't want to do that, use an automotive brake cleaner and spray in the rails while moving the carriage back and forth, that should loosen it up, dis-assembly would unleash the angry mechanical gods upon you, might want to keep the spray away from the motor and belt as they are apparently scarce, otherwise toss it and find an old gray Underwood in good condition and go
Dec 17, 2012 | Underwood 1980s 565 Cr Electric Portable...
How do i replace ink cartridge
Remove the paper scroll from the printer. Turn off the power and make sure the print wheel has stopped moving.
Slide the printer cover toward the back of the machine to remove it. Lift out the old ribbon and replace it with the new one by facing the black side of the ribbon up. Secure one of the reels to its reel shaft, thread the ribbon around the outside of the metal guides, and secure the other reel to the opposite reel shaft.
Tighten any slack ribbon by turning one of the reels
Replace the print cover and reset the paper scroll.
May 02, 2011 | Sharp EL-2615G Calculator
Please can you send me a picture of how to install the ribbon in to the Remington Standard No.12 typewriter. Or tell me how to thread the ribbon.
Hi, first of all there is no picture diagram for this and this method am giving you is what has been used to install ribbon on different typewriters.
  • Remove the existing ribbon. Note the path that the ribbon takes as it goes from one spool to the other.
  • Roll the ribbon entirely on to one of the two reels if your replacement ribbon didn't come with a take-up reel. If your new ribbon has a take-up reel, skip this step.
  • Attach the end of the new ribbon to the take-up reel if your new ribbon doesn't already have one. In most cases, there is a sharp arrow shaped piece on the reel. Use that arrow to penetrate the ribbon and make a few winds of ribbon around the take-up reel.
  • Slip the take-up reel on the take-up spindle on the right side of the typewriter. Align any tabs designed to turn the reel to move the ribbon during typing.
  • Feed the ribbon through the path you noted when removing the old ribbon and place the main ribbon on the spindle. Give the take-up reel a few turns to make sure the ribbon moves freely through the typewriter mechanism.
Jan 18, 2011 | Office Equipment & Supplies
How do I install a new ribbon on the smith corona electra 220 typewriter and where can I find a manual for this?
This is a sensitive installation, i will advice you follow and adhere to the installation instruction from the the manual of you unit, you can search for the manual at manualsonline.com.
Take care.
Oct 23, 2010 | Smith Corona Office Equipment & Supplies
How do I replace the ribbon on an Underwood typewriter?
Really? An Underwood typewriter?
First, do you have a replacement ribbon that is not dried out? Does the ribbon come on one spool or two?
If the typewriter already has a ribbon installed, it is a simple matter of noting the path the current ribbon follows, and which way the ribbon winds onto the spools. Then install the new ribbon following exactly the same threading path. If there is not already a ribbon installed, then it is a little more complicated, and it will depend on your spatial relationship visualization skills.
1. Type a few letters on the typewriter, and take note of which way the spools turn.
2. Mount the two new spools containing the new ribbon so that the full spool will supply (unwind), and the empty spool will take-up (wind) the ribbon.
3. Thread the ribbon through all of the guides in the threading path - there are probably about 6-8 guides that the ribbon has to go through. The most important guides are the ones that carry the ribbon in front of the typeface elements as they strike the paper. But equally important are the guides that monitor the tension of the ribbon - they will cause the spool advance mechanism to reverse the ribbon take-up direction when the ribbon reaches the end of travel.
Sep 22, 2009 | Office Equipment & Supplies
Can someone tell me how to install a ribbon in an old underwood typewriter?
Almost all manual typewriters are roughly the same. The ribbon winds to the outside of the spools, put it on the spindles that way, from the spool to the outside of the guide roll, tru the slot in the reversing arm tru the ribbon lift and back the same way to the other spool.
Apr 06, 2009 | Office Equipment & Supplies
Does anyone know how to thread a ribbon in an old underwood typewriter?
I'll try as they are all pretty much the same. First type with the ribbon off to determine witch way the ribbon winds either to the outside (most common) or to the inside. Drop the ribbon on, if there is a reversing eyelet in the ribbon be sure it is wrapped onto the spool. The ribbon comes off the spool then there may be a guide or roll for it to pass around, then it will go thruogh the reversing arm then through the ribbon lifter aback the opposite way to the other spool DickyO
k24674
jasbo
jasbo
