Question about KitchenAid 24 in. KUDS02SR Built-in Dishwasher
KitchenAid 24 in KUDM0IT JWH0 auto test mode? Starts, fills, but doesn't wash or rinse, just hums, drains fine. There was **** in the screen with the chopper under the filter (clogged) a piece of glass got caught under there, I removed it, it worked fine until I removed the glass. I just did the auto test mode thing and it did some filling and then drained. Still not working though
MNfisherman
  • 11896 Answers
SOURCE: Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Posted on Feb 02, 2009
  • 236 Answers
SOURCE: i have a kitchenaid superba dishwasher wont drain
does it make a buzzing sound when on pump? if so then the pump is trying but is either jammed or there is a blockage in the waste hose/outlet u bend. try seeing if there is a blockage in the waste hose first.
Posted on Mar 13, 2009
  • 37 Answers
SOURCE: kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Posted on Mar 16, 2009
  • 423 Answers
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Posted on Apr 10, 2009
localwonder
  • 6784 Answers
SOURCE: Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Posted on Jun 21, 2009
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
KitchenAid fills and drains but won't wash
With a lot of such appliances, the pump motor runs one way to wash, reverse to pump out. Refusal to do this usually is a loose wire, poor connection in the timer, or a wire on wrong. Check the schematic carefully for that.
Nov 30, 2013 | KitchenAid 34 in. KUDP01FLSS Stainless...
Does not go into wash mode but jumps to rinse and drain
Perhaps you already know how to do this; but if not, check out this video and learn to run a diagnostic test for error codes:
http://www.youtube.com/watch?v=yoCTzbl4FPs
Let me know.
Jan 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
KitchenAid 24 in. KUDS02SR Built-in Dishwasher Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
