Question about Intel Motherboard
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek onboard LAN controller wont start and I get error code 10 and there is no connection recognzed. The connection worked perfectly with the other MB. I tried uninstalling the device and letting it reload, but get the same error. The device indicates the most recent driver is installed. It seems BIOS related... Any ideas?
    Scholar:
  • 155 Answers
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Posted on Mar 19, 2011
Ga-h61m-s2v-b3 not coming on using power switch
I agree with Mike, but would like to add a couple of things. I had the same problem with a Gigabyte board (new install) and found that I had to change the CMOS battery. I put in a new batter, and "voila" it worked fine after that. Also, not knowing your level of experience, make sure the front panel connections are on correctly. Generally speaking, if you look at the lettering on the plastic ends that plug into the board pins on the front panel connector, the lettering should face the edge of the board and not be facing the middle of the board. That too has caused a similar sounding problem in the past. Other than these two potential solutions, more information is definitely needed.
Mar 20, 2014 | Gigabyte Motherboard Ga-H61M-s2P-B3 Core...
Motherboard resets after a second from turning on.
Swap out the ram, if no result! I would think about replacing the motherboard.
Mar 15, 2012 | Gigabyte motherboard - GA-P67A-UD4
The graphics card along with all the other components are in, and when i fire up the computer the monitor gets a signal from the graphics card but nothing comes up on the screen. We tried 3 different...
Hi, try to look in the bios settings for fault.
The PCI-E settings are maybe wrong
You can download a manual here:
http://www.msi.com/product/mb/P67A-C43--B3-.html#?div=Manual
It should be able to show you how you do that.
Here you also find drivers.
Hope this was helpfull.
Aug 14, 2011 | MSI P67aC43 B3 Lga1155 Intel P67 B3 Ddr3...
No Bios on startup. On ga-p67a-ud3-b3
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
if you still have problems with this post a reply
hope this helps
Aug 04, 2011 | Gigabyte Computers & Internet
I have gigabyte p67 ud4 motherboard and i get 1 long beep and 2 short beeps i reseated the video card and the ram i checked every power connector they all are connected
Your mainboard may be one of the mainboards on the P67 Chipset in that the SATA Controller dies.
These mainboards have been recalled by Intel, you should contact the place of purchase for warranty support.
Try to turn on the PC with no SATA devices connected.
Claim warranty support ASAP!
Be sure to rate this solution, thumbs up!
Thanking you
damnor01
Mar 18, 2011 | Gigabyte motherboard - GA-P67A-UD4
Installed new Gigabyte GA-P67A-UD7 mother board. Have checked the connections numerous times. It starts up and then shuts down in about a sec. I even unplugged the 8 pin 12 v connector to try and locate...
When mounting a motherboard to the case you need to add some spacers between them so the MB doesn't contact the case directly, most the MBs today have a protection to shut down so they don't get burned
Try starting your computer outside the case (you can use a key or a screwdriver for the power pins to start it).
Feb 14, 2011 | Intel Motherboard
I HAVE AN INTEL D845GLLY MB WITH 1.6 GHZ PENTIUM 4 PROCESSOR AND 512 MB RAM AND VGA SUPPORT I HAVE INSTALLED WINDOWS VISTA BUT MY MOTHER BOARD CD DOESNOT RUN IN IT IT RUNS IN XP ENVIRONMENT AN APPCRASH...
today also some models of 845 chipset motherboards available in the market.Try to get the mother board cd of latest 845 chip set.
else you better go to xp
Jan 25, 2010 | Computers & Internet
Intel Motherboard Logo
229 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
