Question about Nikon COOLPIX S230 Digital Camera
Well i have a nikon x230 , ive dropped it , and when I turned it on it says "lens error" , please help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 02, 2012
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: nikon coolpix l3 lens error
i solved this problem by calling nikon. they said to fully charge the battery for a couple of hours. mine didn't work, so i called back and they told me to send it in for a repair and that's what i'm doing because i have a 4 year warranty on mine.
Posted on Feb 21, 2008
  • 122 Answers
SOURCE: I dropped my Nikon L18
you jammed the lense neds to be taken to a camera repair person It needs a new lense assmbly .
Posted on Jan 01, 2009
Rammsteins
  • 300 Answers
SOURCE: Nikon Coolpix Lens Error
Hi!
It could be focus system problem - most likely stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Posted on Sep 27, 2009
  • 11967 Answers
SOURCE: Nikon Coolpix S210 Digital Camera .Lens Error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 30, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
Dropped camera on lens and now it wont open properly. says "lens error"
Unfortunately the lens has been damaged in the fall seizing up the motor or gears, the repairs would exceed the cost of a new digital camera.
Jun 06, 2011 | Nikon COOLPIX S570 Digital Camera
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
Dropped camera while it was turned on - now "lens error" appears on screen & can't turn off camera or view pictures
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 25, 2010 | Nikon COOLPIX L20 Digital Camera
I have a nikon coolpix s220. when i turn it on it trys to focus and cannot. it then gives me "lens error" message and turns it's self off. is this fixable? your help is greatly appreciated. ...
Nov 24, 2010 | Nikon Cameras
'Lens Error'
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Dec 28, 2007 | Nikon Coolpix S50 Digital Camera
Lens
hi, Nikon L series is so delicate that repairing is hardly possible so you have to take it to nikon shop where it can be replaced by new one. I dont think anyone can help you either than Nikon. good luck...
Aug 02, 2006 | Nikon COOLPIX L2 Digital Camera
Nikon COOLPIX S230 Digital Camera Logo
18 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
