Question about Schumacher 10 Amp Fully Automatic/Manual Charger by
Lost manual ...how long should i charge my riding mowers battery and on what setting .. i have a 10 amp twin rate slid state charger model number se 40ma
    Scholar:
  • 122 Answers
The SE40MAP has an automatic shutoff when battery is fully charged.
Posted on Jun 07, 2011
  • Wizzard 300 Jun 07, 2011
    The documentation claims the following:
    Recharges automobile batteries in 3 to 7 hours and recreational deep cycle batteries in 8 to 11 hours.
    Silicone control rectifier senses battery condition to prevent overcharge.
    Solid state automatic charger has shutoff when battery is fully charged, then reduces to a maintenance level .
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Battery drained after use
A lot of automotive parts stores will check a battery for free...
find your lowest amp rated (less than 10) and charge it over night.
Have battery load tested.
if good, place ammeter between battery and the rest of the tractor to check and see if load from running engine is draining or alternator isn't working.
or fast way to check an alternator on almost anything, start with battery, the pull off the negative (black) cable, if engine dies nothing is powering the engine but the battery (on an alternator driven electrical system, the battery is only used to start the engine)
May 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Proper battery charger settings for Husqvarna tractor battery, 12V
You will want to charge this at 6 - 10 amps 12v for a few hours, then check the battery for charge.
Oct 05, 2010 | Husqvarna Garden
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
May 30, 2010 | Schumacher & Fast Charge Starter Charger
Is the 10 amp se-40ma battery charger to big for my motorcycle battery can it over heat or over charge it
A battery that might sit for a month at a time, would only need a trickle charge or about 1 amp, a charger of this type can stay hooked to the battery for the whole month. A 10 amp would be for a quick charge or only about 4 - 12 hours depends on how fast the battery lost the charge. A 10 amp charge would cook the battery if left for days.
Mar 26, 2010 | Schumacher 10 Amp Fully Automatic/Manual...
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
Schumacher 10 Amp Fully Automatic/Manual Charger by Logo
431 people viewed this question
Top Schumacher Hardware & Accessories Experts
jdthefixer
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
