Question about HP Compaq Computer Speakers
How do I turn off the internal speaker and only use the desktop speakers?
  • HP Master
  • 27,725 Answers
Click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps
Posted on Mar 19, 2011
  • cynsabeans Apr 12, 2011
    ooh, I found this on computerhope:
    1. Open Device Manager
    2. In Device Manager click View and click "Show hidden devices"
    3. This should make "Non-Plug and Play Drivers" visible in Device Manager.
    4. Expand Non-Plug and Play Drivers by clicking the plus and double-click Beep.
    5. Within the "Beep properties" window click the Driver tab.
    6. Under the driver tab if you wish to temporarily disable this device click the Stop button. If you wish to permanently disable this device under the Startup Type select Disabled.
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
No sound from internal speakers
Is your sound muted? Is the volume turned down to zero? Is the device driver installed and working? Is the cable connected from the computer to the monitor? What is the make and model of your monitor and the model of your desktop computer? Desktop towers don't usually have internal speakers.
Sep 27, 2013 | Lenovo Computers & Internet
How to activate internal speaker
for internal speakers there is a connection in motherboard...u should connect speaker cable to that connection........if external speakers works then only this solution will works
May 29, 2012 | Dell OptiPlex 780 MT Desktop Computer...
To disable internal speaker in hp6000 pc
The internal speaker should be disabled when you plug in external speakers.
If not go to Start > Control Panel > Sounds, Speech, and Audio Devices
> Pick a task.......>Change the speaker settings >Audio tab.
[ Note* An internal speaker can be used for the BIOS Beep Codes. If it is this speaker should not be disabled.
BIOS Beep Codes are the way the computer tells you something is wrong, and an area to look into, for it ]
Regards,
joecoolvette
Jan 21, 2012 | HP Computers & Internet
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
My internal speeker not working
Dell Inspiron Desktop systems have no internal speaker for audio, only a beep speaker on the motherboard for no post diagnosis. For audio you'll need a set of powered external speakers.
Mar 21, 2011 | Dell Inspiron Desktop with Intel Pentium...
PCV-RX770 Sony Vaio Digital Studio PC. Usually when I unplug the speakers, the sound comes through the CPU. The speakers are not plugged in, the volume shows normal, the mute is not on. How do I turn the...
have you tried going to start then go to control panel then go to sounds and audio devices and look to see if the internal speakers are turned on. most pc's will turn them off when they see external speakers pluged in then when you unplug the speakers you have to go these steps to fix the problem.
Jun 10, 2010 | Sony VAIO PCV-J200 PC Desktop
I can listen to sound using my earphones on my Dell Optiplex GX520 but cannot hear anything through the internal speakers otherwise. How do I turn them on?
the internal speaker is only for beeps. These beeps are constant or short and only happen when the computer is trying to tell you how its about to die lol.
Buy some speakers. I would highly recommend a 2.1 system from logitech.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010370060%2050001080%201090608149&bop=And&ShowDeactivatedMark=False&Order=PRICE
Apr 06, 2010 | Dell OptiPlex GX520 PC Desktop
HP Pavillion Desktop no internal speaker?
No it won't. You will have to go out and buy external speakers.
Jun 15, 2009 | HP Compaq Computer Speakers
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
HP Compaq Computer Speakers Logo
508 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
