Question about Kenmore Dryers
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
  • 1,531 Answers
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuitymy kenmore elec. dryer 67042 - seth765.jpgseth765_0.jpg
Posted on Mar 19, 2011
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
How to replace belt on kenmore model 11087673100 Dryer?
there should be a belt diagram on one of the inside panels to the unit
Best regards
Ck
Aug 18, 2011 | Summit Commercial Summit CEDC392PQ ELEC...
Kenmore Gas Dryer Model Number 110.70882990. I must replace the Fabric Dryer switch but am not able to remove the two plastic trim caps and end caps that hold the console panel together. Please help.
Iwopink --
First you need to remove all the sheet metal screws on the console back panel. The plastic side trim cap pieces are clip-fit. Look carefully at the dis-assembly diagrams online.
PDF service manual is available for download at:
[http://www.allrepairmanuals.com/kenmore-dryer.htm?model_number=110.70882990]
Replacement parts are available from:
[http://www.searspartsdirect.com/partsdirect/]
Owners manual is available at:
[http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=11070882990+KENMORE]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore 73952 Gas Dryer
Where do i find belt routing diagrams?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Depending on the model Kenmore you have, you will refer to either diagram H, B, or K. If you have trouble being able to determine which diagram you should use, please post back with your complete MODEL NUMBER so I can assist you further. I hope you find this information helpful.
Apr 21, 2010 | Kenmore 62602 Electric Dryer
Dryer won't get hot
The machine must be repaired, most of the repairs below require a technician.
Check thermal fuse at the back and ensure that the door is closing well.
Check if the fan is working , if it is not working test and eventually replace fan assembly.
If the fan is ok check if the heating element is working, eventually test it with a multimeter.
Test also the thermostat and eventually have a look at the door latch.
If the machine still does not get hot , and all tested part are fine, then replace the control assembly.
If you need a technician ring the number listed on the owners manual.
You can find parts and diagrams for your model entering model number here.
Feb 21, 2009 | Kenmore Dryers
I have A kenmore Elite Model #110.65942400 Ser MR2103237.
before you take it apart make sure you have not lost 1 phase of the 220 volt line into dryer , dryers will run and appear fine on 110 volts be will not heat check fuse or breaker and re-set breaker even if it does not appear tripped , if fuse in line turn off power and remove fuses and check with an ohm meter , then if you have a volt meter check for 220 volts @ socket of dryer , then we will talk dis-assembly
Dec 01, 2008 | Kenmore 659 Electric Dryer
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
I NEED OWNERS MANUAL TO KENMORE DRYER
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Mar 27, 2008 | Kenmore 63942 Dryer
Dryers Logo
134 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
