Question about Bose Companion 2 Computer Speakers
Only get starting sound went starting or shut down computer and there is no sound afterward
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 19, 2011
How do I gqet out of the fixmestick. It keeps coming back every time I start the computer. Cant get into windows at all.
Shut down the computer.
Remove the Fixmestick from the USB port.
Start the computer. Windows should start normally.
There are some viruses that can't be detected while Windows is running. Fixmestick runs instead of Windows to root them out. It removes viruses, but you have to take the stick out of the computer afterward so Windows will run. Here's a link:
How to Start the FixMeStick for Windows
Apr 10, 2018 | The Computers & Internet
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
My battery went dead, so i recharge it and the car starts, now my throttle doesnt work what happend?
Sounds like when the battery went dead, there was still a little power left in it, and when starting was attempted, it went completely dead. This causes the computer to automatically shut down to prevent damage to it. Starting it afterwards may require allowing it to run until it reaches operating temp (when temp gauge is in center), and then restarting one or two times. If this doesn't work, you will need a scan tool to reset pcm.
Sep 20, 2011 | 1997 Mercedes-Benz C-Class
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
Hi Have a Dell Pc Windows 7 OS. it will not shut down unless I hold the button. Start-up in good shut down is always a problem
This is a possible malware or virus attack. Your system is encountering data or system corruption preventing it to execute the command during shut down. Best fix is to reinstall Windows 7 in your computer to erradicate all errors and make sure to install an updated security software (antivirus) afterwards.
Jul 16, 2010 | Dell Vostro 200 PC Desktop
Monitor just went blank, no power light.
Was the PC running, and then shut down? Or, did it never start in the first place?
It sounds like it could be one of many things. Sometimes if the processor fan has failed, the computer will start up, and then shut down. Also, bad memory can cause the PC to shut down.
Jul 05, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
Bose Companion 2 Computer Speakers Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
