Question about Schwinn Mesa Gs Mountain Bike
I have the schwin 2.6 mountain bike and the handlebars came off and I'm trying to figure out how to tighten so wheel will turn
    Brigadier General:
  • 8,546 Answers
Google "threadless stem installation" for videos
Posted on Mar 20, 2011
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
Stem and handlebar stripped
The bolt should be replaced from a spare at a bike shop and tightened to the specified torque for safety. The turning tube should be checked for damage and that it can turn freely. The last thing you want is steering locking up or a separating handle bar while cycling at 40 km/h!
Apr 10, 2014 | Huffy 26" Rock Creek Dual Suspension...
The stem is loose when im riding but i tightend the L key on the top tight as possible n neck still loost any idea?
There are typically two allen bolts that mount on the side of the handlebar stem. Those should be tightened. The top one should only be tightened to remove up and down play in the headset. If you tighten the top one too tight, steering will feel clunky. Only tighten the top one tight enough to remove the up/down play. Use the side bolts to keep the handlebars from turning relative to the wheel.
Feb 11, 2014 | Mongoose 29in Torment Mountain Bike -...
Girls 24inch glacierpoint magna bike can't raise handle bars seems like a allen type screw in middle of bar just turns and still can't lift bar does that need to be replaced or is it something else
If that allen screw just turns both directions, and it won't tighten and it won't raise up when you loosen it, then the wedge nut at the other end of that screw has already fallen off inside. Or it could mean that the screw is broken. Turn the bike upside down and see if you can remove the screw. If it is broken, the repair will be difficult, but not impossible for a bike mechanic. If the screw comes out intact, then the only thing holding the handlbar stem in place is a bit of rust. Put the bike back upright. Stand over the bike as if you were going to ride it. Grip the front wheel between your knees and twist the handlebars as if you were steering while preventing the wheel from turning with your knees. Once it breaks free, pull it all of the way out. Turn the bike over again and the wedge nut should fall out. When you reassemble, take heed of the marking on the handlebar stem so that you don't raise the stem too high. Good luck. Please vote if you found this helpful. Al K
Mar 07, 2011 | Pacific International Pacific Chromium...
How do i raise the handlebar on a 1999 MGX bicycle?
You can only raise a quill stem os far safely. Loosen the vertical center bolt that's in line with the steerer tube a few turns and then tap down on it with a block of wood or rubber mallet to unseat it. The stem should be loose enough to turn independently of the front wheel. You can also raise it somewhat, but look carefully for the "maximum height" or equivalent markings etched into the stem body. Don't expose any more stem than up to that line. Line up your handlebars with the front wheel and securely tighten that bolt. It should be tight enough to vigorously resist independent rotation when you hold the front wheel bewteen your knees and attempt to turn the handlebars.
If it's a new-style threadless type stem, the maximum height was determined when they assembled the bike because they had to cut the steerer tube to be below the top edge of the stem. Go to a Bike Shop and have them replace the stem with one that has a higher rise or shorter reach.
Aug 22, 2010 | Mongoose MGX Maxim Dual Suspension...
The handle bar got very loose while i was using it it suddenly went to the left this is a staionary bike the schwin areodyne can i fix this? i cannot afford repairs seems there is a big lug nut holdind...
http://www.fitnessrepairparts.com/diagram/113 This is an on-line link to the schematics for your Airdyne. The large nut between the handlebar (foot part) and the wheel hub are supposed to be pretty snug. Tighten the nut using a 6 or 8 adjustable wrench and tighten the nut clockwise. Be careful not to tighten too hard or the handlebar will not move at all. This is a very easy fix.
Jul 11, 2010 | Schwinn Original Airdyne
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How do I raise handlebar
usual is the undo the alan key or imbus key bolt in the middle of the handlebar stem. only undo this a couple of turns until the handle bars can move from side to side if you undo too much the locking sears inside the stem may fall off into the folks and are difficult to retreived and reset back onto to your stem. and its usually a dirty job.
Once your handlebars are loose pull up to desired level and retighten.
best way is to stand with the front wheel griped between the legs facing backward between the handlebars lifting up with a left to right rocking motion on the bars. Do not over tighten as this may cause the stem to bond inside the forks and not release in years to come.
it is usual that a bit of grease is in this area to stop the metals bonding inside each other.
Jan 01, 2010 | Mongoose Maneuver Mountain Bike
Schwinn Mesa Gs Mountain Bike Logo
105 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
