Question about Roper RT21AKXKQ Top Freezer Refrigerator
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
    President:
  • 2,468 Answers
The drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Posted on Mar 19, 2011
Testimonial: "Thanks for the info. with a blow dryer , and turkey baster and a hour worth of fun, we finally got it to drain."
Fridge constantly leaks water. The freezer has no issues at all, but the bottom half is always covered in water/ice, I can't keep anything on the top shelf or it freezes, and of course all the drawers...
i haven't worked on a roper but i'm sure it's the same as any other machine,first tilt the machine back by raising the front legs so the doors close with a gentle push,then remove the freezer inside wall,melt out any ice and under the evap coil check the drain hole,pour hot water into the hole to make sure it's draining,usually if water is leaking into the fridge section it's a blocked drain.let me know what you find and i'll help you as much as i can
May 14, 2011 | Roper RT18HDXKQ Top Freezer Refrigerator
Drain hole stopped up in freezer and we cant get it unstopped and it is leaking down in to frige. do you know how we can get it unstopped?
pull back panel in freezer, take hair dryer and melt ice around drain hole until it starts to drain may take sometime usually 20 30 mins pour hot water in drain pan to verify that it is draining
Jan 03, 2010 | Roper Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water leak
My frige was doing the same thing. The drain plug was frozen. Try checking your drain plug, which is located behind the panel on the back side of the unit.
Mar 30, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Dec 31, 2008 | Refrigerators
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Roper RT21AKXKQ Top Freezer Refrigerator Logo
794 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
