Question about Mad Catz Rock Band 3 Wireless Keyboard and Software Bundle for Xbox 360
Can't sync keyboard for Rock Band 3 with Wii!! Keeps flashing.
Rockband 3 guitar for rock band
put new battiers in the mic and the guitar
Dec 30, 2012 | Nintendo Rock Band for Wii
I bought rock band 3 for wii. I plugged in the dongle for the keyboard and followed the sync instructions exactly. the lights flash on both devices, but when I let go of the sync buttons, the lights on...
This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
Dec 31, 2010 | Rock Band 3 Wireless Keyboard
Will the wii rock band keybaord work with the lego rock band game?
Sorry but the keyboard will not work with the Lego RockBand game. You can import most of the songs from Lego Rock Band into Rock Band 3 but you need to purchase the import key from the playstation store.
Dec 26, 2010 | Rock Band 3 Wireless Keyboard
Have rockband game been trying to sync guitar but all that keeps happening is the blue lights on guitar and dongle keep flashing. Please help
Are you pressing the sync buttons on the component and then pressing the sync button on the console?It is under the large door on the front of the console.First press the guitar sync,then it should give you a couple of seconds to press the console sync.If the light goes to constant blue,it is synched.Do the same for the other component.Good luck and rock on!
Jul 30, 2010 | Nintendo Rock Band for Wii
How do you sync the drumset for the wii
Turn on the drums (bottom of pads)
Press and hold the Drum Logo until it begins flashing.
press the sync button on the wii as well as on the bottom of the drum pads. That will sync the drum set with your nintendo wii.
Now Rock Out & Bang Away !!!
Mar 04, 2010 | Nintendo Rock Band for Wii
Lights flashing on guitar and usb
If you are using the Fender Stratocaster Rock Band Guitar:
1) Ensure you have fresh batteries in the Wireless Guitar
2) Insert receiver into USB hub
3) Turn on Guitar via switch on back.
4) If both the guitar and the USB receiver is flashing blue, then press the guitar logo button until flashing blue light on the receiver stops flashing.
Note that on Rock Band 1, non-Rock Band guitars (ie: Guitar Hero and Wiimote based guitars) generally don't work.
Jan 19, 2009 | Nintendo Rock Band for Wii
How to sync the Les Paul guitar with world tour for the wii
guitar hero controllers were not meant to be compatible with rock band on wii for some dumb reason, the only rock band compatible with those guitars is rock band 2, my world tour guitar doesn't even register on rb1
Jan 04, 2009 | Nintendo Rock Band for Wii
Rock band guitar will not sync to wii
For me it was the white box that connects to the back of the wii. I tried everything from changing batteries in the guitar, to pressing white button on guitar, to restarting while holding white button down to screaming at the wii. Then I bought a new rockband guitar at best buy and the new guitar did not work until I swapped the white box (dongle?) that connects to the back of the Wii. One is for the drums and the other is for the guitars and mic. Hope this helps.
Jan 03, 2009 | Nintendo Wii Rock Band Guitar for Wii
Syncing with Rock Band.
From Harmonix spokesperson: "Support for the GHIII guitar peripherals in Rock Band on the Wii was not possible without Activision's permission. Therefore, any questions regarding lack of compatibility with GH III hardware should be directed to Activision."
http://www.joystiq.com/2008/03/24/tabulator-guitar-hero-rock-band-guitar-compatibility/
Sorry to hear.
Sep 20, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Mad Catz Rock Band 3 Wireless Keyboard and Software Bundle for Xbox 360 Logo
74 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
Robert Little
Level 1 Expert
DROPNDEAL
DROPNDEAL
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
