Question about Chicco Caddy - Navy Blue Umbrella Stroller
The rubber foot rest snapped & broke off, where can I buy a replacement for it?
E99670 short shank, or snap on presser feet?
Make sure--Does the machine take a short shank presser foot? If so, you can replace it with a short shank zig-zag presser foot. You can probably go to a regular sewing machine repair shop and find a replacement presser foot.
**NOTE--the links below are examples of what is available. I cannot vouch for these vendors as I've never purchased from them. Do your own due diligence before purchasing!!!
Here's an open toe presser foot:
Open Toe embroidery satin stitch foot Low Short Shank Babylock Bro White...
or a regular zig-zag foot:
http://www.ebay.com/itm/Vintage-ZIGZAG-FOOT-Fits-Singer-Pffaff-Other-Mfrs-Low-Short-Shank-Apps-MPN-C24-/401237995786?hash=item5d6ba5f10a:g:8UcAAOSweWVXcubS
OR you can buy a short shank adapter and a kit of snap-on presser feet that will give you a big variety of different kinds of presser feet, probably including a zipper foot, hemmer foot, 1/4" quilting foot, darning foot, teflon foot, etc....(probably more than she will ever use!) The snap-on kits are available online, try eBay or some of the other sites. They most likely are not Singer brand, but are most likely generic. However, if your granddaughter is just learning, this may be the broadest variety of choices.
These are examples of snap-on presser feet available.
Snap-on Adapter example (most kits do not include the adapter):
http://www.ebay.com/itm/Low-Shank-Presser-Foot-Holder-Adapter-Snap-on-Singer-Kenmore-Juki-Elna-Janome-/222013366993?hash=item33b10722d1:g:Sa0AAOSwJb9WsRpp
Snap-on kits- examples:
42 PCS Domestic Sewing Machine Foot Feet Snap On For Brother Singer Set...
http://www.ebay.com/itm/1-Set-32-Pcs-Domestic-Sewing-Machine-Foot-Feet-Snap-On-For-Brother-Singer-Janome-/282017920492?hash=item41a993f5ec:g:MrAAAOSwMVFXH3rP
Dec 10, 2016 | Sewing Machines
Where can I purchase a quilting foot for this machine in Louisville KY.
you can try a sewing machine store in your area or you could buy one from online, try these sites, sewvacdoctor.com and sewingpartsonline.com
Feb 11, 2016 | Sewing Machines
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
Jan 17, 2016 | Kenmore Sewing Machines
Lafer spring
I have Lafer Kiri chair and spring for foot rest broke
i found replacement spring at Lowes
It is Hillman replacement spring 2 per pkg
Bar code 08236 80104
Works great
Nov 30, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
How do I attach the darning foot on a Pfaff Expressions 2.0 please?
on the machine, there is a foot holder attached to the machine, & the feet to the machine will either be snapped on to the foot holder or there is a screw to undo. most of the new machine are snap on feet, take the presser bar lever up, there is a little lever on the back of the foot holder, & you push it toward the foot holder bar & it will release the foot & you put the other foot down on the needle plate & bring the foot holder bar down on the foot until it snaps on to the foot
May 04, 2012 | Sewing Machines
Bugaboo bee i have a 2007 bee ant the foot rest part you know were they rest there legs is after snapping off,could i replace it and whats my best options
The foot rest is part of the frame and not available as a part. Plastic can be welded google plastic welders or bumper repair to find a local work shop.
If you find this helpful please rate it!
Oct 07, 2011 | Bugaboo 2010 Bee Stroller
Got bernina 1015 sport sewing machinewith one foot want to buy zip,buttonhole &overlock foot is ther a special number or do all bernina feet fit al types of bernina machines
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Jul 24, 2011 | Sewing Machines
I have a logitech mk300 wireless keyboard but one of the flip legs that makes it upright broke. It's a small plastic piece that snaps in the back. Is it possible to get a replacement?
Hi, I would just go to the hardware store and buy some of those rubber or plastic "feet" or "pads" that you can stick on your keyboard. You could also cut out some rubber squares and attach with crazy glue. Hank
Aug 30, 2010 | Computers & Internet
The foot rest is broken
my caboose stroller foot rest it broke where can i replace it
Aug 08, 2010 | Joovy Caboose Blue Standard Stroller
Inside the walking foot a piece of metal broke
I would contact the manufacturer and ask about it. Maybe a replacement part is available.
May 31, 2010 | Sewing Machines
Chicco Caddy - Navy Blue Umbrella Stroller Logo
273 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
thegtw
Dorel UK
Dorel UK
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
