Question about Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
I have the Maytag Atlantis Top Load Washer - it is about 4 1/2 years old. It is starting to make a squeeking noise during the rinse cycle on the "Regular" wash mode, seems mostly on heavy loads. What could this be & how do I fix it?
  • stewartbunch Sep 15, 2008
    September 15, 2008
    I have same problem with a Maytag Atlantis MAV7501EWW - this was happening for approx 2 weeks. Purchased in Feb 2004. Then the washer died yesterday. Made a buzzing sound when I started the cycle but nothing happened, then I smelled something. Unplugged quickly, but outlet was not the problem. Something within the machine must have blown a fuse or something.
    When I replugged in today, turned on still heard buzzing sound. Unplugged again.
    Any suggestions on troubleshooting the problem?
    Kristine
  • cmgruesbeck Oct 23, 2008
    Just had the repair man out to look at it (Maytag Atlantis MAV8551AWW). The bottom seal is going bad on the transmission. There is an extended warranty on machine by Maytag on the transmission for years 3-10 covering parts only. The noise at the end of the spin cycle is the brake going bad. Overall cost for repair $230. By the way, you can no longer get this machine and two years ago Whirlpool bought out Maytag, so if you get an 2008 model you are insured to not have this same transmission type.
Anyone know how to open up the top or gain access into Maytag top Loader washers (Bravos MVWB750WQ)
Posted on Jan 01, 2013
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Posted on Oct 06, 2008
  • germanboy Oct 06, 2008
    I have a later model Maytag Atlantis about 3 years old. It makes a loud screech noise when it brakes the spin cycle. It is not the belt as it has the correct tension. Also does anybody know how the transmission operates? Only a small hose goes to the tub/trans, no wiring. Thanks, Scott.
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
212 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
