Question about Saitek X52 Flight Control System
I've downloaded the sst software and drivers for my X52 Flight Controller (NOT PRO) when I downloaded the profiles for the X52 Flight controller ALL of the profiles (pr0 format) say 'can't load file. I've been able to make a profile from scratch, but haven't been able to use any pre-defined profiles on the web so far.
  • 1 more comment
  • John Attanaiso Mar 19, 2011
    Yes they are the same and I've downloaded from the saitek site the profiles 3 different times without results. When I go into the profile editor and open ANY of the (pr0) profiles I get the same error that the file can't load. When I make a profile from scratch and then save it with the same extention it works fine. I don't want to have to create all of my profiles from scratch. I also have a cyborg EVO and use the same programs and editors which work fine only with those files I've created from scratch and I can't load any official profiles from Saitek's web site.
    I can assign the profile but when I try to open and edit the same official profile I get the error "can't load file'
    yes I have installed the latest programs and drivers from Saitek site
    I don't know what else I can add. Below is what I asked and tried to clarify for the previous tech:
    Problem with the Saitek X52 Flight Control System
    View Comments
    Comments and Clarifications:
    1.
    * pegasiprod
    * 59 minutes ago
    1.
    * pegasiprod
    * 49 minutes ago
    I can assign the profile but when I try to open and edit the same official profile I get the error "can't load file' yes I have installed the latest programs and drivers from Saitek site
    Guru:
  • 767 Answers
According to the manual you can choose your profile by using the clutch function. Are the profiles that you downloaded of the same file type as the one you have been able to make from scratch?
Posted on Mar 19, 2011
  • 1 more comment
  • Jean-Pierre Damstra
    Jean-Pierre Damstra Mar 19, 2011
    You should also check that the driver you downloaded is official and the latest one available. Go here to get to the Saitek website download center. Then in the Choose your product type" box select Joysticks. Then from the Select Product box choose X52. Then you will be prompted to select your Operating system. After you choose your operating system you will then be able to download the latest official drivers as well as the software.
    You can get official profiles here. If these are the profiles you already have then follow these steps to view the suggested profile assignments, make modifications, and add new assignments.
    1. Unzip and deposit the profiles into your Saitek profile folder. On XP, this is located in C:\Documents and Settings\All Users\Documents. On Vista, it's in C:\Users\Public\Documents, and Windows 7 the folder is located in your Documents Library.
    2. Open your profile editor, and then use the 'open' function to view a profile.
    3. To assign a function to a button, right click a button cell in the editor. The menu will show all the commands saved to the profile document. Left click the command name and it will be assigned to that button.
    4. Repeat this process for any other commands you want to add.
    5. Once you are happy with your setup, click the Save As button and give your new profile a name. You can save over the existing one if you want, but it may be best to keep this one unchanged as a template for new profiles.
    6. You can then activate the profile by clicking the profile button (blue target reticule) in the editor window. Alternatively, once saved, the profile will appear in your Saitek icon menu located in the system tray. Left click on the profile name to activate, and click clear profile to deactivate the profile.
    I see, this may be just a programming fault by the part of the Saitek team. I suggest conatcting them and finding out if this has happened to anyone else and what can be done to fix it. You can view their contact information here.
X52 pro mouse function
How to bring up other e-mail that not opened a while: khanhctrinh@gmail.com ?
Jan 13, 2014 | Saitek X52 Pro Flight Control System Game...
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
Jun 14, 2011 | Saitek X52 Flight Control System
The official Saitek website only has the drivers for the X52 Pro and so though I only have the standard X52 (not the pro), I used the Pro driver and software. The profile editor does list the standard X52...
Saitek has drivers for the X52 on their website.
Here are some direct links.
XP 32bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_32.exe
XP 64bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_64.exe
If you need further help please let me know.
Hope it helps...
Sep 24, 2010 | Saitek X52 Flight Control System
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Running any microsoft flight simulator 2002,2994 fsx.and using Saitek X52 controllers I get cursor drift across the screen right to left. Without the X52 this does not happen. Will my download of new...
The driver download should solve this problem.
if not it could be campatability problem for your software and you should read up on that,,,:)
If all else fails maybe your hardware is no good and return it.
Nov 13, 2008 | Video Game Consoles & Games
Saitek X52 Flight Control System Logo
570 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
