I've down loaded the usb cable driver supplied on the disc but when i try to get a connection with my gps unit it says during the download there was a file msising and it might not work properly.
  • 26 Answers
Try uninstalling the software that came with the disk and then reinstalling the software.
If you cannot find where to uninstall it then put the disk in and look for an option to uninstall from there.
If the disk gives you an option to repair then you may also try that.
Hope this helps!
Posted on Mar 19, 2011
My computer does not show the USB cable connection with my Garmin c330. I am trying to update the GPS data.
you need to download drivers and then software which you should have got on a disc with the gps unit or you can download from the garmin website
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Mar 10, 2011 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
I recently updated nt2010.20 map since then my nuvi 350 freezes while loading maps i tried reset, hard reset, preboot,when i connect it on USB i cant see device on my PC.is there any way to delete map...
NO!. THE MAPS CAN ONLY BE DELETED USING THE USB CABLE. GO TO GARMIN WEBSITE YOU MAY NEED TO DOWNLOAD THE USB DRIVERS. THEN TRY THE UPDATE AGAIN. IF THE MAPS ARE ON A CD YOU WILL ALSO NEED THE UNLOCK CODES AND THE UNIT SERIAL NUMBER.
Jan 22, 2010 | Garmin Nuvi 350 Car GPS Receiver
Home dock is connected to usb port of computer
try downloading the newest version of the software from TOMTOM's website. Download and install it first allowing it to put the necessary drivers on the computer. the software will prompt you to connect the gps after the drivers have been loaded.
Hope that helps
Jan 03, 2010 | Tomtom GO GPS Receiver
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Apple ipod Noano 3rd generation 4gb
It could be that the interface on the IPod is bad or the IPod cable is bad. I would try another cable to see if that fixes the problem.
Jun 08, 2008 | Apple iPod nano 3rd Generation
Garmin legand c
Just some suggestions:
Have you tried another USB cable and/or another USB Port?
The cables are not fault proof and yours may be damaged.
After testing the cable, if you are still unsure of the cable, try the USB cable with another device to see if it will work with the other device. If yes, then it is probably not the cable.
Your comment "I can hear it ding when pluged in but says the proper plug in is not there" suggests a software problem.
Did you Uninstall the driver before trying the downloads and factory disk? Try this but use the factory disk in the first instance as this worked before (you can update later).
Have you gone in to Device Manager to check to see if there are problems with any of your hardware (especially the USB Controllers and the GPS Unit itself. To find Device Manager - RIGHT click on My Computer - select Properties - then click on Device Manager.
Problems show up as a yellow exclamation mark.
If you see any of these - RIGHT click the device - go to Properties - and select Reinstall or Update driver.
Note: These instructions are for Windows OS.
Good luck.
Apr 09, 2008 | Garmin 010-00358-00 GPS Receiver
Garmin Map update 2008
you will need to install the usb driver which should be located on the 2008 disk. When you attach the gps to your computer it should ask where the usb driver is located. If your dvd drive is (D) click browse and go the disk and find usb driver folder. I have purchased the new 2008 disk and had problems with it freezing on loader loading. I then browsed the disk and downloaded and then was able to get to the maps. I did not install it due to it asking what map I want to download. I wanted the whole thing so needless to say I am taking it back to walmart. I hope this helps.
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garminc330 GPS
These would be the drivers that allow your computer to interact with your gps unit. If you use it as a standalone unit, then you won't need them. If you plan on saving waypoints and tracks or prerouting yourself and then loading it to your gps, then you will need to install the usb drivers from your installation disk, or from the garmin site before connecting your gps to the usb cable from your computer. Once loaded, you should be able to communicate with your unit and up/down load information.
Nov 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
