Question about Car Audio & Video
How can i tell if my amp is blown - Car Audio & Video
  • 902 Answers
Check your amps fuses if they are blown thats your problem also check the fuse underneath the hood from the cable going to the amp if that fuse is blown fix it. that will turn ur amp back on. also if your blue remote wire is loose it will not tell the amp to turn on. thats how u can tell. if all fuses are intack. and blue wire is then its blown
Posted on Mar 19, 2011
What fuse controls the blower motor and cigar lighter
You people need to list the year, make, model, & engine size, when asking a question. It helps when we know which vehicle it is.
All I can tell you right now, is take of the cover to the fuse box, it should be marked on the inside of the cover. If not & your blower motor & cigarette light are both not working & you suspect a fuse,
you will need a test light, clip it to a good ground, then with the key on (motor off) touch the little metal taps that are on each side of where it states the size of the fuse, the test light should light, when you touch each tab, if it only lights on one side, then that means that side is the hit side & the fuse is blown preventing the current from traveling to the other side to feed the power to whatever circuit your testing. One you find the blown fuse, you can pull it & see it's blown
Jan 06, 2015 | Cars & Trucks
Amplifier blown.
Pls tell me why you think it's blown and just watch the partsnumbers
with are stuck..... easy fix, totally no need to buy a whole need amp
Feb 03, 2014 | Behringer Eurolive B212A Speaker
Coolant in spark plug wells, blown head gasket?
Do a combustion leak test at coolant filler cap,
for exhaust gasses
Clean up coolant in plug wells & pressure test
cold & hot
Mar 04, 2013 | Holden Cars & Trucks
Right speaker quit working after 6 months
swop the speakers overs this will tell you weather it is the speaker or the amp. if the speaker then it has blown or the crossover unit has blown. the crossover unit splits the signal to the bass /middle and top frequencies. if you want an easy way out after you have checked the speakers/amp by swoping them just go and buy a new pair but make the sure they are the same impedance as the old pair as you can easily damage the amp
Apr 10, 2011 | M-Audio Studiophile AV 40 Monitor Studio...
Blown fuse please tell me how many amps it has
AMPS IS ON THE BLOWED FUSE.WHAT EVER NUMBER ON FUSE THATS YOUR FUSE AMPS.
Jul 17, 2010 | 2006 Volkswagen Jetta
Amp is in protect mode
If you have'nt fixed your amp by now I thought I'd tell ya a couple of things why it's going into protect. The basics. Blown subs, bad power suply or mosfets, and blown output transistors/mosfets. Still need help let me know. I repair amps for a living and i'm the cheapest you'll find and honest. I also give the longest warranty. I'm tired of other people rippin people off on repairs. Let me know.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Apr 24, 2010 | MA Audio HK401SX Car Audio Amplifier
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
How can you tell if your amp is blown.
Hello lilgeiger111,
If you have checked all of the wiring and fuses and the amp does not power up, it's blown.
Hope this helps.
Aug 18, 2009 | Visonik Car Audio & Video
Only one thump when car is turned on. problem in amp strength or subwoofer?
try pluging in a diff, speaker to the amp see if u get sound.try powering the sub with a home radio just to see if u get sound at all if ur getting sound from the sub then its the amp but u could of damaged it when the amp over heated
May 03, 2009 | Kicker SoloX S10X2 Car Subwoofer
Explode Amp
Is the equiptment used? Your subs may be blown, try disconnecting them from the amp, then power it up, and then see if it still blows fuses. If it does, your subs are either wired incorrectly, or blown.
Aug 05, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
258 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
