Question about Exercise & Fitness
I have a problem with my treadmill. Just bought it on e bay, its an energizer commercial 20 km treadmill, so the manual says, yet the only thing it says on it is TREADMILL where the motor is covered(so I cant find it anywhere on internet to get help). It seems to work perfectly in every department and looks virtually brand new, however when i run on it every time my right foot goes down it rubs on the deck underneath accompanied by a very obvious rubbing sound just under my right foot. After trying tightening and loosening the belt i am sure it is not this, however from inspection on the inside of the belt there is a line that runs all the way down the treadmill that has a different look to the rest of the belt and this is just where my right foot goes. I was then convinced it was this and have started running to the left of the line which worked fine until just now as when I was running it started to rub underneath my right foot once again and this time accompanied by a burning rubber smell. I would be massively grateful if anyone can help me as I cant find any info or problems like this on any sites I have looked at.
KTMEXC250
  • 31 Answers
SOURCE: sounds like tire rub when turning right or left
It may be your power steering. Try checking the level of the power steering fluid. If you are not familiar with where this is check your owners manual and it will definitely tell you where it's located under the hood. If the fluid is at a good level it is most likely something to do with your wheel alignment. This can only be checked and serviced by a licenced motor mechanic or specialist alignment centre.
Good luck
Posted on Nov 11, 2009
  • 566 Answers
SOURCE: Rubbing sound in motor when car is running.
hi from uk may i offer advice ? considering age of car and possible high milage ?? if you have not replaced the cambelt+tensioner which should be donearound 60,000 mls have it checked asap as if belt or tensioner fails you are looking at serious damage ! however this rubbing noise? may turn out to be some other fault like alternator bearing? or water pump but as you mention rubbing and especially grinding? i would suspect c/belt+tensioner ? so resist driving too far untill this noise is investigated sorry unable to provide a diagnosis as have not heard noise but hope you take advice given ?
Posted on Dec 11, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a Proform 380 Treadmill. When the treadmill
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Posted on May 24, 2010
  • 12 Answers
SOURCE: Treadmill turns on (electronics work)
Sounds as though you may need to replace the motor for the tread belt. I can't quote you a price for certain but if you have the skills to disassemble the treadmill you could replace the dead motor with a working one provided that the output shaft, wattage, and amperage of the replacement are the same.
Posted on Mar 05, 2011
electrotech1
  • 1126 Answers
SOURCE: we start using our treadmil
the control processor has some garbage in it do to a small power surge and if you unplug it for 40Min, it should reset back to normal
Posted on Sep 02, 2011
HOW DO I FIND THE COMPUTER FACTORY RESET BUTTON ON REEBOK TREADMILL MODEL 14301
There is no reset button, the only thing you can do is unplug it for 10-20 minutes, if it is going to reset it will, if not you have a hard fault that must be addressed by a qualified repair person.
Aug 22, 2016 | Reebok Exercise & Fitness
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
3 beeps every 3 sec
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > 60 minutes.
Yellow LED marked 60 MIN energizes.
Check for F/S stuck closed (up), WV leaking by, HGV leaking by, TXV not feeding
properly, low charge, or inefficient compressor.
Jul 15, 2010 | Hoshizaki Commercial Freezer KM-500MAH
I am looking for a owner's manual for CardioZone treadmill Model CZ SG65. I can't find anything on the internet.....can anyone help?
Go to treadmilldoctor.com or call them@ 1-800-750-4766 since Keys Fitness went out of business they bought the parts inventory I am assuming that they will have manual for you unit.
May 07, 2010 | Cardiozone Supersport Hr Club Commercial...
Hoggan Sprint Runner ltreadmill very noisy
I am the marketing director for HOGGAN Health. Check out the youtube.com video below, it will show you how to re-track the runner. If that doesn't help, call us: 800-678-7888 or visit HOGGAN Health Runner Treadmill for more info.
Jun 17, 2009 | Sportime Hoggan Sprint Runner Treadmill
Exercise & Fitness Logo
89 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
