Question about HP e-PC 42 PC Desktop
Running ubuntu on (old!) hp e-pc 42; need Windows. Would it be worthwhile installing Vista? How about 7? Thanks.
  • 26 Answers
Based on the specs of your computer I don't recommend that you upgrade to either one of those. You would not want to use Vista because it would run really slow on your computer, and Vista itself is not very good. And if you can't run Vista, you most likely can't run Windows 7 because it requires even more than Vista.
I recommend that you use Windows XP, not only because aside from Windows 7 and Snow Leopard it is my favorite Operating System, it is also the OS that was originally shipped with that specific model computer.
Short answer: Go with Windows XP
Hope this helps!
Posted on Mar 19, 2011
What luck has anyone had with Windows 7 on this machine?
You could try leaving the system restore for a bit longer. It MIGHT get past 99%. However, you can often run into issues with creating the restore disk. If the disk is currupt, there isn't much you can do about it.
Since Ubuntu ran perfectly, there isnt any other problem with the computer. Running a clean install of Vista/7 or even 8 is obviously an option that will work. You will have to buy the product though.
Otherwise, you could stick to Linux. The software center is really good, and getting used to the environment doesn't take too long.
Aug 27, 2014 | Compaq CQ60-420US PC Notebook
How can i see files created in windows os after installing ubuntu 14.04 tls
when you computer turns on it should automatically ask you what os you would like to boot from. on a side note of you go into your harddrive you should find a folder named "windows" or
"windows old" and all the files you saved should be in there. seems to me that u install'd ubuntu over windows and now only have ubuntu on your computer... but you should still have that windows folder if you chose not to delete you files.making a new partition does not mean you will have 2 os's on your computer... hope this all helps.
Jun 29, 2014 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
Can I install the hard drive of my old hp 8510p in my hp presario cq 42? will it run the old windows vista? My new hp presario cq 42 is running the new windows 7?
If the hard drive is compatible with your presario cq 41 then it will work. The operating system does not matter if you're switching hard drives.
If you want to update the operating system on the old hard drive, you will need to have the software for Windows 7.
Jun 14, 2011 | Compaq Computers & Internet
I put ubuntu the computer over heet and now only work the trial of ubuntu. how vista can run again?
If you erased the Windows partition when you installed Ubuntu you will need to re-insert your Windows Vista disc and reinstall Windows over Ubuntu using that, This will only work if you have enough keys remaining on your Windows Vista License, however. Hope this helps.
Mar 15, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Hi there.I've hp compaq 5610b laptop and using vista operating system.Is it possible to use another operating system in my computer?Plz help me!
You can install the previous version of Windows - this is Windows XP or you can install the latest version of Windows - this is Windows 7.
You can install a Linux operating system such as Ubuntu or Red Hat
Google search for Linux operating systems to download Linux freeware program.
Dec 16, 2010 | HP Compaq 6510b PC Notebook
Right, i just installed ubuntu, then overwrite my vista drive, i have a vista disk but i don't know how to overwrite the linux bootloader with vista. last time i tried this if failed.
To re-install Windows Vista please do the following:
Put the disc in and restart the computer
Boot from the disc
Do a full system install
Delete your partition [contains Ubuntu(Linux)]
and install.
I recently did this last week, went from Ubuntu back to windows 7, and currently I duel-boot both Operating Systems. I hope this helps!
Please don't forget to rate :), Thanks!
Oct 07, 2010 | Computers & Internet
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
NO OS OF HP COMPAQ
If your computer does not have an operating system then you will need to purchase one. You can still buy Windows XP but with Windows 7 coming out very soon it would be wiser to pick up a copy of Vista with a free upgrade coupon to Windows 7. Or you can run a linux o/s if you a famaliar with linux. Ubuntu I believe is a free linux o/s that you can download to a flashdrive and install to your pc. Hope these tips help.
Sep 20, 2009 | HP Compaq Business Desktop dc5750 - Athlon...
HP e-PC 42 PC Desktop Logo
197 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
