Question about Smeg 3.46 cu. ft. / 98 liter Upright Freezer UKVI144B
We have a ukvi144b freezer that is not cooling the warning light is on aswell can itbe fixed?
  • 4 Answers
Hi you will maybe find that it has leaked some gas or the compressor is about to go either way it may be cheaper just to replace.
Posted on Mar 21, 2011
I've got a proline Freezer and the red warning light is on..and is not freezing if it neededgas is it expensive.
how much is everything in your freezer worth???or how much will you be putting in your freezer worth??? it is cheaper to fix the freezer than losing all that money on food
May 30, 2015 | Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Magic Chef MCCF5WBX clicks but compressor won't come on
if it just hums or buzzez you will need to check the start capacitor on the compressor if it is stuffed you need to buy around 15uf---25uf cap @400volts depending on the size of the motor
Nov 19, 2012 | Magic Chef Chest Freezer MCCF5WBX
Temperature warning light came on. Removed
dear sir/madam
i think its tempretor sensor /thermostat problem please try to find thermostat needele and keep in right position , and check its tempretor satting if it,s need to reset please reset it . i hope after that it will working good. if not please try to contect your freezer maintanance perssonel for repair/reset your freezer .
hope answer the question.
thank you
please vote!
Jul 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Smeg 3.46 cu. ft. / 98 liter Upright Freezer UKVI144B Logo
63 people viewed this question
Top Smeg Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Smeg Freezer Expert? Answer questions, earn points and help others
