Question about Eljer & Patriot& Elongated Toilet Bowl
Toilet is only a couple years old but gets a ring at the water line that won't come off. I have 3 other toilets in the house much, much older that don't have this problem. This one is rarely used. Disappointed so hard to clean when fairly new. Any ideas? Gill
  • 528 Answers
The problem is as you said it is rarely used and the ring is from the lime build up from the water evaporating at the same line all the time. You will need to use or at least flush the toilet more often and maybe put a auto type bowl cleaner unit in this toilet. The auto unit I speak of would be a hang in or tablet type. http://www.bing.com/shopping/searchq=auto+toilet+bowl+cleaner&FORM=HURE
I do not mean to recommend on over any other.
Posted on Mar 19, 2011
How do I fix toilet almost overflowing?
This is the part that you need,easy to install,your's is the old type,just turn water off,then flush,then remove excess water and install,has instructions with it,Walmart,Home depot,or Lowe's has it,cost less than 10 bucks,I use these.
Jul 26, 2015 | Home
Tip
How to reset your toilet
Things you'll need.
New toilet bowl bolts, wax ring, toilet flex supply line (if you don't plan on re-usings old) , crescent wrench, channel locks, plastic cup, newspaper, hack saw, towel, protective gloves (latex, vinyl).
First thing is to turn off the water supply to the toilet. Flush your toilet and hold down the lever to get as much water out of the tank as possible. Now take a plastic cup and scoop out the remaining water in bowl, throw into tub or sink.
Take your crescent wrench and un-bolt tank from floor. If bolts spin, I suggest just cutting them right below the nut, being careful not to scratch or break your toilet. Your toilet will break or crack if your put to much pressure on it, the most common spot for a crack is by the bolt holes. Dissconect supply line from tank holding cup below it to catch the water, if supply line is flex you can leave attached to shut-off valve, if rigid, remove from shut-off valve. Use towel to wipe up water.
Place newspaper out on floor. Stand over toilet facing the tank, your legs on either side of bowl, grab toilet right in front of tank on the bowl. pick straight up, your going to be hunched over while your carrying the toilet and walking like a penguin, just try to keep toilet level as you carry to newspaper.
Remove old seal from bottom of toilet and around toilet drain. Wear gloves and put spoils into plastic bag. Use screw driver to scrape any chunks up. Clean area. Remove old bolts from toilet ring and place new ones in. If toilet ring is broke, call a plumber. Place new wax ring on toilet ring. Make sure bolts are pointing straight up. Get toilet above bolts and lower slowly guiding bolts through toilet holes. After toilet is on, push with light steady pressure straight down to help wax ring spread out even and make new seal. If toilet is leaning towards wall as you push then compensate to have it lower level as possible. Never use a cold wax ring, have it at room temperature. After its lowered sit on toilet for a minute.
Remove any wax that has oozed out and place nuts on bolts, with washers going on first. Hand tighten both sides, then take crescent wrench and tighten down slowly alternating sides, a couple turns on one side then a couple on the other making the toilet set level and ensuring a good seal.
Do not over tighten As it gets harder to turn nut, take your index and thumb and pinch the end of the wrench. Hold with enough force to just hold the wrench, tighten until your fingers slip off. That's the best way I can describe how to tighten bolts safely with out damaging your toilet, if there is a leak you may need to tighten a bit more, use your best judgment. Use hack saw to cut-off excess of bolt,
Attach your supply line and turn water back on slowly. Test for leaks, if no leaks your good.
Do not caulk around your toilet: all that does is turn a leak into a disaster by keeping it hidden from you, Eventually your sub floor will rot and you will have a huge repair bill.
Other Tips:
http://www.fixya.com/support/r5204270-slow_shower_drain_fix
http://www.fixya.com/support/r5197305-stop_water_sweat_solder_water_line
http://www.fixya.com/support/r5245506-leaking_shut_off_valve_hard_close_shut 5e9c605.gif
on Jul 06, 2010 | Plumbing
The bolts on my toilet are loose and the whole toilet moves when I sit on it
Is the entire closet bolt to the flange turning as you try to tighten down on the nut? If so, use a pair of vise grips on the tip end of the closet bolt; while holding the vise grips firmly in place to keep the bolt from turning, use an open end wrench to turn the nut.
If the closet bolt still turns, you may have a problem where the closet bolt shifted out of position on the flange or the flange itself broke (extremely rare in both scenarios)- but a possibility- if so, turn off the water supply line to the toilet at the shut-off; unscrew the water supply line at the shut-off valve; cut the bolts just below the nut; remove the toilet.
Clean off the old wax ring from the toilet and the flange. Inspect the flange for any damage, replace if necessary.
You'll need to replace the wax ring; there are two types, one with a horn and one without the horn- so make sure use inspect the old wax ring you removed to see if it had a horn or not attached to the wax ring.
Btw, if your particular application requires the horn, the horn end fits down into the flange/soil pipe assembly.
You'll also have to replace the old closet bolts. All your necessary supplies can be purchased at you local plumbing supply house or home improvement centers. Assembly is the reverse of the disassembly
Feb 16, 2015 | Home
Toilte leaks in front have chk the lines and find no leaks. Is it the toilte
If you have found no leaks on the supply line, be sure to check the seal between the tank and the bowl. This is a common source of leaks, especially on older toilets that have seen much use.
Before you do that though, check carefully at the base of toilet to see if its possible any water is appearing from under the toilet. Your toilet sits on a seal, most often made of wax (sometimes rubber) that seals the water and waste from the toilet into the drain pipe. Normally, those seals last many years. Flush the toilet 3-4 times and observe whether any water seeps out under the toilet. Give it a few minutes (4-5) and recheck. If it is leaking, the fix is pretty simple: Shut off the water, disconnect the source water line just so you won't risk breaking it, and remove the 2-4 toilet bolts. Rock the toilet gently and pull straight up until the seal comes loose. The beeswax seals seem to work the best. Scape off as much of the old wax as you can, and set a new one. They are very inexpensive, and sell for around $2-3.00 USD. To reinstall, remove the protective lining (if present) on the wax, place the ring on the toilet, not the flange and carefully place it straight down onto the flange. Try not to make a mistake - line it up carefully. Press down on the toilet's seat area, maybe rocking yourself a little, until you can see the toilet is back in position.
Next, VERY CAREFULLY tighten the toilet's mounting bolts, a bit at a time, until secure. Over-tightening can break porcelain toilets, so be careful.
OK - either that's fixed or you've ruled it out. Next is the tank seal. Unfortunately, the only way to get to it is take the tank off. If its come to that, first go to the hardware store and secure a replacement set containing the tank seal, a new pair of brass bolts, and the bolt seals. Expect to pay around $4-5.00 USD for the set. The job is pretty easy, you use a wide flat-bladed screwdriver to loosen the (usually) brass screws in the bottom of the tank after shutting off the water and while an assistant holds the nuts from the bottom. You COULD do if yourself, but an assistant makes it easier. Carefully lift off the tank, and you'll see the seal. Remove it, and replace it with the new one, being careful to put it in the right direction, as they are usually cone-shaped. Set the tank back on, put the screws back in, using new seals/bolts (just for good luck) and reassemble. BE CAREFUL when tightening the bolts!! You can easily crack the tank if overtightened.
This is a lot of writing, but just to give you an idea, I could probably change a wax ring in 10 minutes, and the tank seal in 15 or so. Best wishes -
Jun 09, 2014 | Electronics - Others
We have 3 toilets in the house. the tanks won't refill after flushing
You may have dirt getting into your water from the well and clogging the fill valves in your toilets. Valve assembly can be opened and cleaned out from the top. Instructions are available on AS website for your model. (Note) If you are picking up material from your well, a sediment filter should be added to your water line.
Apr 15, 2012 | American Standard Home
HOW DO I CHANGE FLUSH SEAL ON KOHLER ONE PEICE TOILET
The flush seal is the rubber gasket between the tank and the bowl. You do not have one. So I am guessing you mean the wax ring on the floor?? They usually only get replaced when the toilet is changed, unless you spring a leak. Or are you talking about the flapper inside the tank that holds the water till the flush lever is pulled? Get a new flapper, if it is just the flapper you need, otherwise you will have to buy the whole thing, all these parts are available at the hardware store. I think it is held on by a couple screws in there, might just be a press fit, we don't see too many one piece toilets. And the wax ring is about $2, but the toilet has to be unbolted from the floor and water disconnected, clean off the old wax, put on the new ring, smoosh it back down and bolt it back it up. Don't for get the water line. Check to make sure you have no leaks. Hope this helps.
May 23, 2010 | Kohler K-3386-0 Rialto one-piece...
American Standard Cadet 3 - bowl water slowly drains
try putting some food coloring in it to see if it's leaking anywhere. the coloring will help you identify where it's leaking
Aug 21, 2009 | American Standard Cadet 3 Right Height...
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Aug 27, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Eljer & Patriot& Elongated Toilet Bowl  Logo
105 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
