Question about Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
Whirlpool Calypso washer error messages op and ld.
  • rkeyser Aug 27, 2008
    I had the LD problem and confirmed that the drain pump was
    broken. The motor would spin, but the splined steel shaft slipped in the
    plastic pump rotor (who designed that?). I ordered the new, improved motor/pump
    (twice as fast, single unit construction), but my wife wanted the washer fixed
    NOW. So as a temporary fix, I mixed up a little blob of JB Weld epoxy and
    glued the shaft into the pump. I waited overnight and then gave it the
    test. It is working fine after several loads. I guess I'll still replace it when the new pump arrives, but I wonder how long it might last if I just stuck with the glued pump.
Op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Posted on Sep 02, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I do not have an owners manual for my Calypso washer. What does the LD sign mean?
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get LD error/ fault when washing
This error code means long drain.
What this means is that the drain is either clogged or kinked. Please inspect your washers drain hose and than press stop/cancel to clear the code.
Jan 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Ld and ob error codes
hello.........
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
656 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
