Question about Hotpoint Refrigerators
I have a fridge/freezer about 15 years old. Have just noticed that the fridge is showing a temp of 22oC what do you think is wrong with it. I have never had anything go wrong with it before.
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Hi ive hoover hrfa54w fridge freezer just over a year old. Ive noticed freezer is starting to defrost sometimes the freeze again....its in a holiday cottage so often in a very cold ambient temperatur
Ambient temp will cause the thermostat some confusion. There's probably nothing wrong with the fridge, my freezer doesn't like being in the outhouse. Only alternative is only switch on when you are there or move it to a cupboard where you could put a low output source of heat just enough to keep it happy. Then get it out when you are there?
Jan 25, 2015 | Hoover Refrigerators
The fridge is too warm (15) but the temp. is set at 4. The temp. indicator sometimes shows 2 but the temp. inside the fridge is still 15
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
GE side x side refridgerator temperature is
unlikely both temp.sensors will be faulty at the same time. Notice how different the internal temps.are compared to the acurate one you are measuring it against. Almost certain board is defective because incorrect info in the processor will tell the compressor/s to switch off before time.(hence not correct temp. all the time.) Suggest replacement.I normally replace probes as well to eliminate problems later..
Sep 17, 2009 | Refrigerators
GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Feb 16, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn Aire side by side - freezer and fridge not working
Yes the compressor could be stuck but it's also possible the PTC could have failed - each will show the same symptoms. If you're a tech you can check the compressor or you can just replace the PTC also known as "relay". Part # 12002784 should run somewhere around $60.
Dec 30, 2007 | Jenn-Air JCD2389G Side by Side...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Open Questions:
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
