Question about LG 19LG30 19 in. LCD HDTV
There is a no signal on my monitor but it is a pc monitor now how to change it
    Genius:
  • 1,114 Answers
You can go into the menu and select which channel you want to receive on. (hdmi,cab,video, etc....)
Posted on Mar 19, 2011
How do i get rid of "CHECK SIGNAL CABLE" on my 17" flatron wide monitor?
"Check Signal Cable" message is shown on the monitor only when their is disconnection between PC & monitor or if the cable is faulty. You can get rid of the message, which is built-in the monitor. Try changing the faulty cable.
sonsunny
Jun 28, 2011 | Dell Dimension 3000 PC Desktop
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
No signal
Dec 16, 2010 | AOpen F2705 17" LCD Monitor
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
SIGNAL OUT OF RANGE MESSAGE
Sounds like your PC has changed resolution to one not compatible with your monitor. Try to boot in safe mode to change the resolution to more basic. Then reboot.
Monitor Mike
Apr 24, 2010 | Optiquest Computers & Internet
Apple 1081 monitor with PC reverts to 600 x800 when rebooting PC
800 x 600 is bios settings its not receiving the signal to change, check the screen size settings in control panel, this can also be a cable problem as the signal is sent to the monitor to change settings.
Dec 28, 2017 | Apple Computers & Internet
NO SIGNAL TO MONITOR
change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Jan 24, 2009 | Intel Motherboard
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
LG 19LG30 19 in. LCD HDTV Logo
