My machine is not wringing out my clothes. - Washing Machines
4 Suggested Answers
  • 1294 Answers
SOURCE: water not wringing out
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 28, 2008
SOURCE: my washing machine makes machine gun sound and
Interesting... I don't have a solution, just a related problem. Belt broke and after repair, I observed that water is leaking from the bottom of the tub during wash cycle. I guess it could be a cracked tub (not too likely) or a gasket around the agitator bearing. I'd like some advice on this as well.... and how to get to it. The drive belt was a pain....
Posted on Sep 10, 2009
  • 48 Answers
SOURCE: Washing machine will not wring clothes out clothes
If the water in your washer has drained out but has not spun the clothes more than likely the motor coupling has broken. That is the component that connects the motor to the transmission. If the motor coupling is intact then it could either be a transmission problem or timer problem. After washing this machine goes into a neutral drain and it drains the water out for around 3 to 4 minutes after draining the timer will pause the motor allowing the transmission to shift into spin. So either the timer is not pausing or the transmission is not coming out of neutral drain. Probably the coupling though. Hope this helps
Posted on Sep 01, 2011
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
The spin cycle on my washing machine is not working, the clothes are still wet when the cycle is finished
Make sure that the clothes are not too heavy ( jeans and sweats ), and put in the machine evenly. If the machine is off balance, it won't spin fast enough to wring out the clothes.
Oct 14, 2010 | Hotpoint Washing Machines
My clothes will not spin to wring out the water
Clutch is bad, Control Panel Bad, or Motor Control Board bad. Usually the clutch you can get a new clutch online fron an appliance parts dealer there are several so shop around. INSIDE THE BACK COVER IS THE OWNERS MANUAL remove a few screws and get it. This will help aid you in self repair of MAYTAG :( I finally gave up and bought an old standard machine and I have no worries or problems with my washing machine, no stinky drum or clothes, no break downs, and no half washes. I ll never buy another high end washer set again, never.
Oct 13, 2009 | Washing Machines
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
