Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Have a celeron motherboard will power up but no beep or video??\r\nit has a video on motherboard
  • 902 Answers
Without a beep its hard to dignose. try clearning the bios info/ remove the cmos battery (looks like a giant watch battery) also there is a jumper next to the batter to reset it. use that jumper by moving the jumper pin over one. if its in clear mode (the jumper) then it wont start. let me know if this helps
Posted on Mar 19, 2011
Beeping black screen
Do you have the manual that came with the motherboard? If you do, it should have a chart indicating what the 3 beeps mean. If not, try INTEL's website. Lots of tech info there. Don't rule out the video or RAM...the problem could be there or several other places.
Sep 01, 2014 | Intel Asrock G41m-vs3 R2.0 Motherboard...
Power on is malfunction ...motherboard is the problem according to the technician
have you try your power supply or your other parts to a working CPU nit?..
These are the list of possible cause black screen : 1. memory - clean the pins by eraser and re-insert it again to a memory slot..(also clean with brush the memory slot before inserting your memery card). 2. CPU processor - once it busted it will no longer on.. 3. PSU (power supply) - it is not enough to supply a power to your system which will result also to black screen. 4. video card - if you hear 3 beeps then clean the pins of the video card if you are using external VC not on your onboard. 5. Motherboard - busted motherboard like capacitors are the main cause of black on the board better to replace new motherboard. 6. Some instances are the grounds of the casing.
In order to test it, use other working CPU and plug it your parts to that cpu, (note: the working cpu should the same on your unit)
Hope it helps. Thanks
Sep 10, 2011 | Computers & Internet
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
I have lost my audio and video driver how can i find them tell me plzzzzzzzzzzzz
this siddu my mother board is not display no beep sounds no display please solution intel p4 mother board
Dec 10, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
The right type of motherboard for compaq presario 2200 pc
Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371793-001 System board (motherboard) - De-featured (DEF) for Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original
Mar 02, 2010 | HP Compaq Presario 2200 Notebook
SOYO's SY-P4VTP with 3GHz Pentium 4 Processor does not bootup.
check the rams and if they are ok
try to reset the bios settings from the motherboard jumper settings. like clear CMOS jumper will be there.
Apr 17, 2009 | Soyo (SY-P4VTP) Motherboard
My system doesnt start
if no beeps (remove the RAM and for sure has to beep if the motherboard is OK) at all and no video signal you may look to:
1. a new PS - power supply or
2. a new CPU or
3. a new motherboard.
Jan 10, 2009 | Intel (SL5TL) Pentium 4, 2 GHz Processor
MSI MS-6754 mother board won't boot and beeps when I swap processors
your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Sep 06, 2008 | Computers & Internet
Boot up problems
The beeps can be either video or memory. Most likely it is memory. Check the memory.
Thanks,
Lolita
Apr 09, 2008 | Mach Speed P4M800 (890552603480)...
No display on monitor
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Dec 28, 2007 | Computers & Internet
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
