I have a dell 3115cn and it appears the ethernet port is bad --have tested it with many cat5 cables that work on other devices. Port lights up 1 second then goes dark. Is there an easy fix? I have another dell 3115cn laying around and if need be can take entire processor board out and reinstall if necessary. If that is the route to take -any tech manuals to help with that?
  • 1,915 Answers
I do not have access to dell manuals but if you have 2 printers you are ideally set. Take a couple of pictures and make notes about the routing and location of any cabling that is attached to the printer and then just disconnect everything and swap the boards. Or if the other printer works, I would just remove the fuser, transfer assembly and cartridges from the printer with the bad ethernet port and put them in the other printer.
Posted on Mar 19, 2011
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
If im connecting everything in my apartment thru a wireless connection, I have been using a netgear wireless adapter on my PC and a Netgear Universal wi-fi internet adapter (model=WNCE2001) for my game...
If I understood you right, you have a wireless router that connects to you're PC and game console wirelessly, now you brought a 5 port switch to use with non-wireless enabled devices. please correct me if I'm wrong.
However, you will not get any extra speed from a 5X port switch, its either 10 Mbps for ethernet, 100 Mbps for fast-ethernet, and its automatically negotiated between the device and the switch therefore you see the "10/100" in every switch/network card specifications, it means it supports auto-negotiation. same goes for 10/100/1000
As per the network cable categories, there's no big difference really between CAT5, CAT5e, CAT6 because they all support the fastethernet (100 Mbps speed), the maximum length should not exceed 100 meters (theoretically), I'd say don't exceed 80 meters from my personal experience. The noticeable difference between the 3 categories (CAT5/5e/6) is the cable thickness, hence, quality.
I hope this answers your questions. feel free if you have any further queries.
Jun 13, 2011 | Computers & Internet
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
What wires go into the back of the Dynex 5 Port 10/100 Fast Ethernet Switch?
A switch is a device for networking computers printers or other devices with an ethernet port. Most common scenario would be to hook a cat5 cable from your broadband router's lan port to Port 1 and then connect your other ethernet devices to the remaining ports. In order for the devices to cmmunicate you'll want to make sure that they are on the same ip subnet. Usually, 192.168.1.x.
Your router may be 192.168.1.1, your PC 192.168.1.100 Printer 192.168.1.101. Each device needs a unique IP address.
Hope that helps.
Oct 21, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
I bought 1 box of belden cat5e for LAN. when i test it with LAN tester the cables are good but when i connect it to the modem/hub it is not connecting.. please help me.. thanks..
If you've tested the cable and your not getting a link light, there is a posibility that either the port in the switch or the network card is bad.You can try moving the cable to an existing working port on the switch to see if it links up. If not then try another device like a laptop or printer with a NIC card on the cable
Sep 07, 2010 | Belden CAT5e Plenum 4Pair...
I have my xbox and computer connected with a ethernet cable and when i test the connection its says not connected
Make sure that on your router, whichever port is connected to the exbox the corresponding light on the front is lit up. Also you need to make sure that you are using a CAT5E Patch cable from the router and not a pc-to-pc networking crossover cable.
If there is no light corresponding to the port you have connected to then there is either a bad connection or you have the wrong cable
May 03, 2010 | Microsoft Xbox 360 Console
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Jul 22, 2009 | Dell Latitude E6400 Laptop
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
k24674
jasbo
jasbo
