Question about GE Dryers
I need a drum belt for my ge gas dryer who would carry them in miami
  • GE Master
  • 3,361 Answers
Marcone Appliance Parts.
telephone (305) 594-0203
Posted on Mar 19, 2011
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Need to identify belt parts for GE Gas Dryer DDG8580RCMWH
Check with an appliance parts supplier or directly with GE.
Jan 26, 2014 | Dryers
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
G.E. Gas dryer starting making thump noise when drying,
The drive belt has lost some of its rubber ribs, you need to replace the belt
Aug 15, 2009 | GE DBXR463EDWW Electric Dryer
Ge Gas Dryer the drum does not turn but motor just hums then kicks out
sounds like motor bearings or drum bearings are froze up and is not turning the belt.
Apr 24, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Gas Dryer Replace the belt Model # DDG8280G
Usually there are one or two panel in the front that are held by some screws. Once removed the top panel is usually attached to the front panel and you can get a screwdriver and release the plastic push in retainers. Prop the top up and the drum is exposed. The belt usually goes around the drum down to a drive pulley on the bottom of the machine. You will need to route the belt around the drum in the front or back to get it routed correctly.
Jul 08, 2008 | GE DVL223GB Gas Dryer
Dryers Logo
37 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
