SUB WOOFER CONE SPLIT LOGITECH Z5500 REPLACEMENT CONE
  • 604 Answers
You should just buy a replacement speaker and install it, replaceing the cone would not be cost effective, in fact you could buy a better speaker and get better bass out of the sytem, try www.martinsoundproducts.com they are in Cleveland and sell many great speakers in all sizes.
Posted on Mar 20, 2011
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
What does it mean if the cone of my sub woofer doesent push down
Voice coil seriously damaged!!!!!!!!!!!!!!! Driver needs replacement due to overdriving/abuse. Not covered by warranty.
Nov 19, 2015 | Car Audio & Video
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Aug 18, 2011 | Logitech X-530 Computer Speakers
Logitech z5500 speakers no power
certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Mar 29, 2010 | Logitech Z-5500 5.1 Digital Speaker System...
Locked up sub-woofer cone won't move?
In theory your idea would work, however you risk damaging your amp by reversing polarity and the positive and negative wires from your head unit are low voltage so they wont provide enough current in reverse or normal polarity to free the cone of your sub. but here is something that you can try that is similar in concept.
Take a positive lead from your head unit and wire it to the negative of your sub. Now ground the positive terminal of your sub to the vehicles chassy using a wire. This creates a 12v-14v reversed polarity current that should be strong enough to (POP) the cone so to speak. hope this helps
Sep 26, 2009 | Jl Audio 12W7 Car Subwoofer
How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Oct 27, 2008 | Logitech Z-340 Computer Speakers
Sub-woofer malfunction
if the amp is going bad repair or replace, the sub you would probably have to replace, this would be the best fix. but check the amp also.good-luck!
Jul 12, 2008 | Logitech Z-5500 Computer Speakers
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Shorted Sub-woofer
try this site first; http://logitech-en-amr.custhelp.com/cgi-... but it sounds as if something has fried in the amp - if you look inside you may well see some burning marks around some of the components. Another possilility is that the cable being pulled out pulled something inside the speaker that has damaged the cone or more likely the power supply , but the symptoms you describe suggest an amplifier issue, possibly caused by damage to the power supply system. Hope this helps :)
Mar 07, 2007 | Logitech Z-560 Computer Speakers
70 people viewed this question
 Grubhead
Grubhead
