Question about Lexmark X4270 All-In-One InkJet Printer
Printer quit working
Hello. I have two laptops set up with DSL internet connection. The intel processor laptop is connected with ethernet to DSL modem; the AMD Athalon laptop is connected by USB port to DSL modem.
The printer stops printing, even though it says it is printing. I took it in for repair and it worked fine at the computer repair shop. The weird thing is though the computer repair guy printed off a print job I had queued a week ago and canceled because it never printed.
I just got print cartridges refilled instead of buying new ones, although it wasn't working with the other print cartridges even when they had ink, so I don't think that is the problem, but I'm no expert.
I do not currently have this printed connected to a fax line, as I am not using the fax at this time and wouldn't know how to set it up with DSL to use the fax anyway. The printer is connected directly to my AMD Athalon laptop.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Try a test page first to determine that the printer has basic abilities.
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
Hello, I have a Brother MFC-5890CN Printer/Fax/Copier which has a wired connection to my PC (Windows 7) & works very well. However I would also like to be able to access the MFC-5890CN from my Laptop...
download the brother network deployment wizard. Run it and
make and executable. run that exe on your laptop. It should do all
the necessary config for you
May 01, 2011 | Brother MFC-5890cn Color Flatbed...
Do I need Wi-Fi to get on the internet on my Acer E-Machines E725/E525 Notebook Laptop Computer. I bought a wireless router and a wireless USB and neither one of them or working even when I put the CD's in...
IF you do NOT have DSL, "but I do not have DSL" (sic) then you must connect up to the internet, via a MODEM, the phone line connects to the Modem, the MODEM connects to the PC via Ethernet cable. Then you use the Connect to internet Wizard. You will need to enter your login and password, for your ISP, so you will be able to access the internet. You also must enter the ISP's PHONE Number to Dial up, FIRST, then you must enter your login, and password. Then you will connect up to your ISP, and be able to go onto the internet through them. That's it, really.
May 13, 2010 | Computers & Internet
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Toshiba laptop
Appreciate the "Ask Me".
On your post, pls try:
  • click on Start, Control Panel, Network Connections;
  • right click on Local Area Connection;
  • click on Properties;
  • click on Configure Button;
  • click on Advanced tab;
  • highlight Connection Type, in the Value box, select Auto-Negotiation;
  • you may be asked to reboot.
You could also try the 100 Base Tx Full Duplex or the 100 Base Tx Half Duplex.
It would seem that the orange led indicates a 100mbps connection while the green is for 10mbps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Toshiba Satellite 1405-S151 Notebook
Won't connect to AT&T DSL service
Most desktop computers do not come standard with wireless connectivity, and the 530s is no exception. To connect to the internet, you will need either an ethernet cable to run between the computer and the DSL box, or a wireless card, which can be installed inside your computer, allowing you to access wireless networks.
Jul 20, 2008 | Dell Inspiron 530s Desktop Computer...
Lan
Okay so if I understand your question....your desktop has DSL and you want to connect your laptop to the same DSL connection? If that is the case then what you need is a router. A router will share the DSL connection between the desktop and the laptop. A wireless router will allow your laptop to surf wirelessly if it has a wireless adapter or you can plug it into the ethernet port on the laptop. You can purchase one here. The instructions are pretty simple and straightforward and should be included with the router.
Jun 25, 2008 | Dell Latitude D600 Notebook
Internet Connection
A few years ago, i too had an IBM thinkpad and encountered some issues as well when connecting to the internet.
The IBM 2647 does not have a built in wireless card, meaning that you need to purchase one from your local electronics store to use wireless internet. The software provided with these CD's can often be quite helpful and will help you set up the connection.
The 2647 only supports an analog modem connection, and the modem in the area you are attempting to connect via ethernet may use a digital modem. Adapters are available although they are quite pricey (ranging from $200 and up.)
Hope this helps.
FerrariXP
Mar 10, 2008 | IBM ThinkPad T20 2647 Notebook
Lexmark X4270 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
