Question about Nikon Speedlight SB-800 TTL Flash
Sb-800 sync When my master sb-800 flashes the sb-800 slave flashes a "couple" of seconds after.
  • 685 Answers
Make sure the slave is not set to rear curtain or slow flash. Otherwise Send that back to Nikon for service. http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Posted on Nov 08, 2009
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    No iTTL mode (or TTL mode) in SB 800 synced with cord to D300
    Bingo! That's an X-sync cable, only for firing the flash, syncing it withe shutter - carries out no auto features or communication with the camera.
    Don't waste your money on another cable the same. There is no TTL light measuring features with an X-sync cable.
    You can, however, get the proper 'off-the-camera' TTL syncing cable either from Nikon or a 3rd party provider. This proper TTL cable can cost a fair bit, I don't know exactly but thinking from $40-$50 to $80'odd.
    Shop around, buy from a store where you have the face-to-face enquiry and a return facility if 'they' get it wrong.
    **.The best way to acknowledge contribution is to rate it's relevance.**
    Feb 04, 2009 | Nikon Speedlight SB-800 TTL Flash
    TTL Multi-Flash Sync Cord SC-27
    YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
    AND SHOOT THE FLASHES IN SETTING 4A
    NO CORDS NEEDED THEN .
    BERRIE SMITH CAMERA REPAIR
    BBMW@BELLSOUTH.NET
    Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    174 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
