Question about Troy Garden
How do you remove the cutting head from a troy-bilt tb525 ec 4 cycle gas trimmer?
  • Roy Cagle
    Roy Cagle Mar 20, 2011
    Can you maybe lock up the gear drive ABOVE the string head with a small diameter screwdriver by putting it into a hole in the side of the drive? On some manufacturers models, this can be done. I presume there is a nut to be removed at the end of the driveshaft to allow removal of the string head but when you turn it, the drive turns with it? I don't have any 4-stroke machines to allow examination at this time. Locking up the engine could facilitate removal of the head also; easily done on a 2-stroke model by removing the plug in the engine and inserting a length of soft, clean rope (like pull start rope) into the cylinder. This probably won't work here is the plug is in the head possibly, not the cylinder where the piston is. Post back and let me know if the lock nut turns the driveshaft when turning it.
Ref: removing cutting head from troy-built trimmer tb525...
Just talked with Troy-Bilt company and got answer on how to remove head. seems that on the tb525, they used 3 heads over the production period. On mine, I had the slot above the head, but there was no deeper hole or notch to engage the screwdriver, etc. My head requires an allen wrench. Use the small part of the "L" shape and angle it into that notch...pointing the tip toward the shaft or engine direction. Then, hold the allen wrench upright and this will lock the shaft. Now you may turn the notched ring on the cutting head in a CCW direction (as you look from bottom to top). It will probably be very tight, but will come off. Hope this helps those who have been having trouble searching for that hole inside the notch that doesn't exist on this particular version. Good luck...
Posted on Aug 06, 2014
  • Mike Coffin
    Mike Coffin Aug 06, 2014
    the specific item number for the tb525 mentioned abovet is 41EDT52C966
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
CAN U SHOE ME WHERE DRIVE SHAFT IS
the drive shaft is a cable that runs from the engine down to the cutting head through the aluminum tube.
Jul 24, 2016 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Starts up when choked then dies. Has a new carb and using 4 cycle fuel that is fresh. Ran great till 3 weeks ago then this.
I just went through the same problem with my Yardworks trimmer that is identical to this. If it starts when chocked after priming but stall immediately would usually indicate that there is no fuel getting to the engine. I also found that switching to non-ethanol premium fuel made all the difference in the world.
Jun 06, 2015 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
When pulling rope it clicks
This is a problem with either the starter pulley ( rope pulley) if the corners are worn it will not engage with the pawls, or the pawl/pawls them selves have worn
Jun 19, 2012 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Cant get the heas off trou-bilt weedeater on a 4 cycle # TB 525-ec
the bolt on the end has left hand threads not right hand the most bolts have
Apr 07, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Sep 05, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
6,214 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
