Question about Intertherm Heating & Cooling
Compressor will not come on in ac mode - Intertherm Heating & Cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Mar 19, 2011
Compressor started with out being turned on and no fan running
If the defrost setting is selected on the controller, the compressor will run. It doesn't need to be turned on through AC selection. Defrost mode allows the compressor to cycle to keep the oil and freon circulating when AC not in use
Sep 06, 2015 | Cars & Trucks
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
When i turn on the windsheald defroster i hear a rattle in the engine
The ac compressor runs in defrost mode.
So the noise could be a belt tensioner or something involving the ac compressor pulley.
Feb 18, 2013 | 2001 Ford Escape
Engine dies as soon as I turn on the air or heat.
If by heat you mean defrost, it could be a seized AC compressor or compressor clutch, since the AC compressor is also engaged when in defrost mode to remove moisture from the air.
Try turning the flat, round plate on the front of the AC compressor by hand (WITH THE ENGINE OFF!!) If turns with only a little resistance, the compressor is most likely NOT your problem. If it not turnable by hand, then your compressor is seized up will most likely need replaced.
Sep 15, 2011 | 2005 GMC Envoy
My 96 Sedan DeVille Climate control system will not toggle between Econ and Auto Modes. It will only operate in the Econ Mode. The Auto Mode lights up when I push the button but immiediately switches...
This usually means the ac refridgerant is low. In Econ mode the ac compressor will not turn on, your car is staying in Econ to avoid damage to the compressor. If you are low on refrigerant it means you have a leak. Don't just buy a can and refil, have a professional shop check for leaks and fill the system with the proper oil and add refrigerant to the proper pressure.
Mar 07, 2011 | Cadillac DeVille Cars & Trucks
My AC for mazda protege 1997 is blowing hot air only; I was told the car had an electrical problem because the AC doesn't come on; but there was pressure when the gauge was attached. How can I solve the...
CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.IF BOTH GOOD YOU HAVE OPEN AC CLUTCH COILOR THE COMPRESSOR FAULTY.IF COMPRESSOR CLUTCH COIL IS OKAY AND COMPRESSOR GOOD.YOU HAVE ELECTRICAL PROBLEM AT THE AC MODE SWITCH.NOT ALLOWING AC AIR DOOR OPEN.
Jun 25, 2010 | 1997 Mazda Protege
AC not stops working when compressor starts.
how many amp service do you have in the house
May 17, 2009 | Heating & Cooling
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
